Successful exploitation of this vulnerability could allow an attacker to bypass user authentication on OPTIMAX installations that make use of the Azure Active Directory Single-Sign On integration.
The following versions of ABB Ability OPTIMAX are affected:
- ABB Ability OPTIMAX 6.1 vers:all/*
- ABB Ability OPTIMAX 6.2 vers:all/*
- ABB Ability OPTIMAX 6.3 <6.3.1-251120
- ABB Ability OPTIMAX 6.4 <6.4.1-251120
| v3 8.1 | ABB | ABB Ability OPTIMAX | Incorrect Implementation of Authentication Algorithm |
- Critical Infrastructure Sectors: Energy, Water and Wastewater
- Company Headquarters Location: Switzerland
CVE-2025-14510
The vulnerability allows an attacker to bypass user authentication on OPTIMAX installations that make use of the Azure Active Directory Single-Sign On integration.
ABB Ability OPTIMAX
ABB
ABB ABB Ability OPTIMAX 6.1: vers:all/*, ABB ABB Ability OPTIMAX 6.2: vers:all/*, ABB ABB Ability OPTIMAX 6.3: <6.3.1-251120, ABB ABB Ability OPTIMAX 6.4: <6.4.1-251120
Ability OPTIMAX 6.3 6.3.1-251120 is a fixed version for CVE-2025-14510
For more information see the associated ABB PSIRT security advisory 9AKK108472A1331 ABB CYBERSECURITY ADVISORY - PDF Version (https://search.abb.com/library/Download.aspx?DocumentID=9AKK108472A1331&LanguageCode=en&DocumentPartId=&Action=Launch), ABB CYBERSECURITY ADVISORY - CSAF Version (https://psirt.abb.com/csaf/2026/9akk108472a1331.json).
Relevant CWE: CWE-303 Incorrect Implementation of Authentication Algorithm
| 3.1 | 8.1 | HIGH | CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:U/C:H/I:H/A:H |
- ABB PSIRT reported this vulnerability to CISA
- Initial Release Date: 2026-04-30
| 2026-04-30 | 1 | Initial Republication of ABB PSIRT 9AKK108472A1331 |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-120-04
