Abb pcm600
Successful exploitation of this vulnerability could allow an attacker to send specially crafted messages to the system node resulting in execution of arbitrary code.
The following versions of ABB PCM600 are affected:
  • PCM600 >=1.5|<=2.13
v3 4.4 ABB ABB PCM600 Improper Limitation of a Pathname to a Restricted Directory ('Path Traversal')
CVE-2018-1002208
A vulnerability exists in the SharpZip.dll included in the product versions listed above. An attacker could exploit vulnerability by providing a specially crafted message to the system node, causing insertion, and running of arbitrary code.
ABB PCM600
ABB
ABB PCM600: >=1.5|<=2.13
The problem is corrected in the following product version: ABB Protection and control IED manager PCM600 version 2.14. ABB recommends that customers apply the update at earliest convenience.
Note: RE_630 protection relays are not compatible with PCM600 version 2.14. When using earlier PCM600 versions with RE_630, the known vulnerability must be mitigated through system-level defenses. For mitigation guidance, refer to the General Security Recommendations.
The following product versions have been fixed: Protection and Control IED manager PCM600 2.14 is a fixed version for CVE-2018-1002208
For more information see the associated ABB PSIRT security advisory 2NGA002813 ABB CYBERSECURITY ADVISORY - PDF version (https://search.abb.com/library/Download.aspx?DocumentID=2NGA002813&LanguageCode=en&DocumentPartId=pdf&Action=Launch), ABB CYBERSECURITY ADVISORY - CSAF version (https://psirt.abb.com/csaf/2025/2nga002813.json).
3.1 4.4 MEDIUM CVSS:3.1/AV:L/AC:H/PR:L/UI:R/S:U/C:N/I:H/A:N
  • ABB PSIRT reported this vulnerability to CISA
No known public exploitation specifically targeting this vulnerability has been reported to CISA at this time. This vulnerability is not exploitable remotely. This vulnerability has a high attack complexity.
  • Initial Release Date: 2026-04-30
2026-04-30 1 Initial Republication of ABB PSIRT 2NGA002813
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-120-02
