Apeman Cameras
Successful exploitation of these vulnerabilities could allow an attacker to take control of the device or view camera feeds.
The following versions of Apeman Cameras are affected:
  • ID71 vers:all/* (CVE-2025-11126, CVE-2025-11851, CVE-2025-11852)
v3 9.8 Apeman Apeman Cameras Insufficiently Protected Credentials, Improper Neutralization of Input During Web Page Generation ('Cross-site Scripting'), Missing Authentication for Critical Function
  • Critical Infrastructure Sectors: Commercial Facilities
  • Company Headquarters Location: China
CVE-2025-11126
A security flaw has been discovered in Apeman ID71 218.53.203.117. This vulnerability affects unknown code of the file /system/www/system.ini. The attack may be performed from remote. The exploit has been released to the public and may be exploited. The vendor was contacted early about this disclosure but did not respond in any way.
Apeman Cameras
Apeman
Apeman ID71: vers:all/*
Apeman did not respond to CISAs request for coordination. Users are encouraged to reach out to Apeman for support https://apemans.com/pages/contactus
CVE-2025-11851
A vulnerability has been found in Apeman ID71 EN75.8.53.20. The affected element is an unknown function of the file /set_alias.cgi. Such manipulation of the argument alias leads to cross site scripting. The attack can be executed remotely. The exploit has been disclosed to the public and may be used. The vendor was contacted early about this disclosure but did not respond in any way.
Apeman Cameras
Apeman
3.1 3.5 LOW CVSS:3.1/AV:N/AC:L/PR:L/UI:R/S:U/C:L/I:N/A:N
CVE-2025-11852
A vulnerability was found in Apeman ID71 218.53.203.117. The impacted element is an unknown function of the file /onvif/device_service of the component ONVIF Service. Performing manipulation results in missing authentication. The attack is possible to be carried out remotely. The exploit has been made public and could be used. The vendor was contacted early about this disclosure but did not respond in any way.
Apeman Cameras
Apeman
3.1 5.3 MEDIUM CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:N/A:N
  • CISA discovered the PoCs (Proof of Concept) as authored by Julio Urena
  • Initial Release Date: 2026-03-10
2026-03-10 1 Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-069-01
