Axis Communications Camera Station Pro, Camera Station, and Device Manager (Update A)
Successful exploitation of these vulnerabilities could result in an attacker executing arbitrary code, executing a man-in-middle style attack, or bypass authentication.
The following versions of Axis Communications Camera Station Pro, Camera Station, and Device Manager are affected:
  • AXIS Camera Station Pro (CVE-2025-30023, CVE-2025-30025, CVE-2025-30026)
  • AXIS Camera Station (CVE-2025-30023, CVE-2025-30026)
  • AXIS Camera Station 5 (CVE-2025-30025)
  • AXIS Device Manager (CVE-2025-30023, CVE-2025-30024, CVE-2025-30025)
v3 9 Axis Communications Axis Communications Camera Station Pro, Camera Station, and Device Manager Deserialization of Untrusted Data, Improper Certificate Validation, Authentication Bypass Using an Alternate Path or Channel
  • Critical Infrastructure Sectors: Commercial Facilities, Critical Manufacturing
  • Company Headquarters Location: Sweden
CVE-2025-30023
The communication protocol used between client and server had a flaw that could lead to an authenticated user performing a remote code execution attack.
Axis Communications
Axis Communications AXIS Camera Station Pro: <6.8, Axis Communications AXIS Camera Station: <5.58, Axis Communications AXIS Device Manager: <5.32
Axis Communications recommends users to upgrade to the following versions:
AXIS Camera Station Pro 6.8 or later
AXIS Camera Station 5.58 or later
AXIS Device Manager 5.32 or later
For more information on these issues, see the following security advisories from Axis: CVE-2025-30023, CVE-2025-30024, CVE-2025-30025, and CVE-2025-30026.
Relevant CWE: CWE-502 Deserialization of Untrusted Data
3.1 9 CRITICAL CVSS:3.1/AV:A/AC:L/PR:L/UI:N/S:C/C:H/I:H/A:H
CVE-2025-30024
The communication protocol used between client and server had a flaw that could be leveraged to execute a man in the middle attack.
Axis Communications
Relevant CWE: CWE-295 Improper Certificate Validation
3.1 6.8 MEDIUM CVSS:3.1/AV:N/AC:H/PR:N/UI:R/S:U/C:H/I:H/A:N
CVE-2025-30025
The communication protocol used between the server process and the service control had a flaw that could lead to a local privilege escalation.
Axis Communications
Axis Communications AXIS Camera Station Pro: <6.8, Axis Communications AXIS Camera Station 5: vers:all/*, Axis Communications AXIS Device Manager: <5.32
For CVE-2025-30025, AXIS Camera Station 5 requires an upgrade to AXIS Camera Station Pro 6.8 or later
3.1 5.2 MEDIUM CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:C/C:N/I:L/A:L
CVE-2025-30026
The AXIS Camera Station Server had a flaw that allowed users to bypass authentication that is normally required.
Axis Communications
Relevant CWE: CWE-288 Authentication Bypass Using an Alternate Path or Channel
3.1 6.1 MEDIUM CVSS:3.1/AV:A/AC:L/PR:N/UI:N/S:C/C:N/I:L/A:L
  • Noam Moshe of Claroty Team82 reported these vulnerabilities to CISA
  • Initial Release Date: 2025-12-18
2025-12-18 1 Initial Publication
2026-01-15 2 Update A - Updated the Affected Products and Mitigations section
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-352-08
