Copeland XWEB and XWEB Pro
Successful exploitation of these vulnerabilities could allow an attacker to bypass authentication, cause a denial-of-service condition, cause memory corruption, and execute arbitrary code.
The following versions of Copeland XWEB and XWEB Pro are affected:
  • XWEB 300D PRO <=1.12.1 (CVE-2026-25085, CVE-2026-21718, CVE-2026-24663, CVE-2026-21389, CVE-2026-25111, CVE-2026-20742, CVE-2026-24517, CVE-2026-25195, CVE-2026-20910, CVE-2026-24689, CVE-2026-25109, CVE-2026-20902, CVE-2026-24695, CVE-2026-25105, CVE-2026-24452, CVE-2026-23702, CVE-2026-25721, CVE-2026-20764, CVE-2026-25196, CVE-2026-25037, CVE-2026-22877, CVE-2026-20797, CVE-2026-3037)
  • XWEB 500D PRO <=1.12.1 (CVE-2026-25085, CVE-2026-21718, CVE-2026-24663, CVE-2026-21389, CVE-2026-25111, CVE-2026-20742, CVE-2026-24517, CVE-2026-25195, CVE-2026-20910, CVE-2026-24689, CVE-2026-25109, CVE-2026-20902, CVE-2026-24695, CVE-2026-25105, CVE-2026-24452, CVE-2026-23702, CVE-2026-25721, CVE-2026-20764, CVE-2026-25196, CVE-2026-25037, CVE-2026-22877, CVE-2026-20797, CVE-2026-3037)
  • XWEB 500B PRO <=1.12.1 (CVE-2026-25085, CVE-2026-21718, CVE-2026-24663, CVE-2026-21389, CVE-2026-25111, CVE-2026-20742, CVE-2026-24517, CVE-2026-25195, CVE-2026-20910, CVE-2026-24689, CVE-2026-25109, CVE-2026-20902, CVE-2026-24695, CVE-2026-25105, CVE-2026-24452, CVE-2026-23702, CVE-2026-25721, CVE-2026-20764, CVE-2026-25196, CVE-2026-25037, CVE-2026-22877, CVE-2026-20797, CVE-2026-3037)
v3 10 Copeland Copeland XWEB and XWEB Pro Unexpected Status Code or Return Value, Use of a Broken or Risky Cryptographic Algorithm, Improper Neutralization of Special Elements used in an OS Command ('OS Command Injection'), Improper Limitation of a Pathname to a Restricted Directory ('Path Traversal'), Stack-based Buffer Overflow
  • Critical Infrastructure Sectors: Commercial Facilities
CVE-2026-25085
A vulnerability exists in Copeland XWEB Pro version 1.12.1 and prior, in which an unexpected return value from the authentication routine is later on processed as a legitimate value, resulting in an authentication bypass.
Copeland
Copeland XWEB 300D PRO: <=1.12.1, Copeland XWEB 500D PRO: <=1.12.1, Copeland XWEB 500B PRO: <=1.12.1
Copeland has provided a fix for the vulnerabilities and recommends users update the XWEB Pro to the latest version by going to their software update page https://webapps.copeland.com/Dixell/Pages/SystemSoftwareUpdate in the sections dedicated to the different XWEBPRO models page.
Alternatively, a user logged into an XWEB Pro with internet access can update XWEB Pro directly from Copeland servers via the menu SYSTEM -- Updates | Network.
Relevant CWE: CWE-394 Unexpected Status Code or Return Value
3.1 8.6 HIGH CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:L/A:L
CVE-2026-21718
An authentication bypass vulnerability exists in Copeland XWEB Pro version 1.12.1 and prior, enabling any attackers to bypass the authentication requirement and achieve pre-authenticated code execution on the system.
Copeland
Relevant CWE: CWE-327 Use of a Broken or Risky Cryptographic Algorithm
CVE-2026-24663
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an unauthenticated attacker to achieve remote code execution on the system by sending a crafted request to the libraries installation route and injecting malicious input into the request body.
Copeland
3.1 9 CRITICAL CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:C/C:H/I:H/A:H
CVE-2026-21389
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by injecting malicious input into the request body sent to the contacts import route.
Copeland
3.1 8 HIGH CVSS:3.1/AV:N/AC:H/PR:H/UI:N/S:C/C:H/I:H/A:H
CVE-2026-25111
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by injecting malicious input into requests sent to the restore route.
Copeland
CVE-2026-20742
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by injecting malicious input into requests sent to the templates route.
Copeland
CVE-2026-24517
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by injecting malicious input into requests sent to the firmware update route.
Copeland
CVE-2026-25195
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by supplying a crafted firmware update file via the firmware update route.
Copeland
CVE-2026-20910
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by injecting malicious input into the devices field of the firmware update update action to achieve remote code execution.
Copeland
CVE-2026-24689
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by injecting malicious input into the devices field of the firmware update apply action.
Copeland
CVE-2026-25109
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by injecting malicious input into the devices field when accessing the get setup route, leading to remote code execution.
Copeland
CVE-2026-20902
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by injecting malicious input into the map filename field during the map upload action of the parameters route.
Copeland
CVE-2026-24695
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by injecting malicious input into OpenSSL argument fields within requests sent to the utility route, leading to remote code execution.
Copeland
CVE-2026-25105
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by injecting malicious input into parameters of the Modbus command tool in the debug route.
Copeland
CVE-2026-24452
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by supplying a crafted template file to the devices route.
Copeland
CVE-2026-23702
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by sending malicious input injected into the server username field of the import preconfiguration action in the API V1 route.
Copeland
CVE-2026-25721
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by injecting malicious input into the server username and/or password fields of the restore action in the API V1 route.
Copeland
CVE-2026-20764
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by providing malicious input via the device hostname configuration which is later processed during system setup, resulting in remote code execution.
Copeland
CVE-2026-25196
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by injecting malicious input into the Wi-Fi SSID and/or password fields can lead to remote code execution when the configuration is processed.
Copeland
CVE-2026-25037
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by configuring a maliciously crafted LCD state which is later processed during system setup, enabling remote code execution.
Copeland
CVE-2026-22877
An arbitrary file-read vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling unauthenticated attackers to read arbitrary files on the system, and potentially causing a denial-of-service attack.
Copeland
3.1 3.7 LOW CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:U/C:L/I:N/A:N
CVE-2026-20797
A stack based buffer overflow exists in an API route of XWEB Pro version 1.12.1 and prior, enabling unauthenticated attackers to cause stack corruption and a termination of the program.
Copeland
3.1 4.3 MEDIUM CVSS:3.1/AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:L
CVE-2026-3037
An OS Command injection vulnerability exists in XWEB Pro version 1.12.1 and prior, enabling an authenticated attacker to achieve remote code execution on the system by modifying malicious input injected into the MBird SMS service URL and/or code via the utility route which is later processed during system setup, leading to remote code execution.
Copeland
  • Amir Zaltzman and Noam Moshe of Claroty Team82 reported these vulnerabilities to CISA
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-057-10
