Daikin Security Gateway
  • CVSS v4 8.8
  • ATTENTION: Exploitable remotely/low attack complexity/public exploits are available
  • Vendor: Daikin Europe N.V
  • Equipment: Security Gateway
  • Vulnerability: Weak Password Recovery Mechanism for Forgotten Password
Successful exploitation of this vulnerability could allow an attacker to gain unauthorized access to the system.
The following versions of Daikin Europe N.V Security Gateway are affected:
  • Security Gateway: App: 100, Frm: 214
3.2.1 WEAK PASSWORD RECOVERY MECHANISM FOR FORGOTTEN PASSWORD CWE-640
Daikin Europe N.V Security Gateway is vulnerable to an authorization bypass through a user-controlled key vulnerability that could allow an attacker to bypass authentication. An unauthorized attacker could access the system without prior credentials.
CVE-2025-10127 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-10127. A base score of 8.8 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:L/VI:L/VA:H/SC:N/SI:N/SA:L).
CISA discovered a public Proof of Concept (PoC) as authored by Gjoko Krstic and reported it to Daikin.
Daikin Europe N.V has reported they will not fix this vulnerability and will respond directly to user inquiries.
For more information, contact Daikin customer support.
  • September 11, 2025: Initial Publication
  • September 18, 2025: Revision - Updated vendor name
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-254-10
