- CVSS v4 8.5
- Vendor: Delta Electronics
- Equipment: CNCSoft-G2
- Vulnerability: Stack-based Buffer Overflow
Successful exploitation of this vulnerability could allow attackers to execute arbitrary code in the context of the current process.
The following versions of Delta Electronics CNCSoft-G2 are affected:
- CNCSoft-G2: Version 2.1.0.27 and prior
Delta Electronics CNCSoft-G2 lacks proper validation of the user-supplied file. If a user opens a malicious file, an attacker can leverage this vulnerability to execute code in the context of the current process.
CVE-2025-58317 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-58317. A base score of 8.5 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:P/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
- CRITICAL INFRASTRUCTURE SECTORS: Critical Manufacturing, Energy
- COMPANY HEADQUARTERS LOCATION: Taiwan
Natnael Samson working with Trend Micro's Zero Day Initiative reported this vulnerability to CISA.
Delta Electronics recommends CNCSoft-G2 users to download and update to Version 2.1.0.34 or later.
General Recommendations:
- Do not click on untrusted Internet links or open unsolicited attachments in emails.
- Avoid exposing control systems and equipment to the Internet.
- Place systems and devices behind a firewall and isolate them from the business network.
- When remote access is required, use a secure access method, such as a virtual private network (VPN).
Users should contact Delta Electronics with any additional product-related support concerns.
For more information, refer to Delta Electronic's product cybersecurity advisory PCSA-2025-00017.
- November 4, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-308-03
