Delta Electronics CNCSoft-G2
Successful exploitation of this vulnerability could result in an attacker achieving remote code execution on the device.
The following versions of Delta Electronics CNCSoft-G2 are affected:
  • CNCSoft-G2
v3 7.8 Delta Electronics Delta Electronics CNCSoft-G2 Out-of-bounds Write
  • Company Headquarters Location: Taiwan
CVE-2026-3094
Delta Electronics CNCSoft-G2 devices prior to version V2.1.0.39 are vulnerable to an Out-of-Bounds Write while parsing DPAX files in the DOPSoft component.
Delta Electronics
Delta Electronics CNCSoft-G2:
Delta Electronics recommends users update to Version 2.1.0.39, which has resolved this vulnerability. The update can be obtained from the Delta Electronics download center at https://downloadcenter.deltaww.com/en-US/DownloadCenter?v=1&q=cncsoft&sort_expr=cdate&sort_dir=DESC.
For more information, see the associated Delta Electronics security advisory Delta-PCSA-2026-00004 which can be downloaded in PDF format here: https://filecenter.deltaww.com/news/download/doc/Delta-PCSA-2026-00004_CNCSoft-G2_File%20Parsing%20Out-Of-Bounds%20Write.pdf
  • Natnael Samson (@NattiSamson) of TrendAI Zero Day Initiative reported this vulnerability to CISA
CISA recommends users take the following measures to protect themselves from social engineering attacks:
  • Initial Release Date: 2026-03-05
2026-03-05 1 Initial Republication of Delta Electronics Delta-PCSA-2026-00004 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-064-01
