EV Energy ev.energy
The following versions of EV Energy ev.energy are affected:
  • ev.energy vers:all/* (CVE-2026-27772, CVE-2026-24445, CVE-2026-26290, CVE-2026-25774)
v3 9.4 EV Energy EV Energy ev.energy Missing Authentication for Critical Function, Improper Restriction of Excessive Authentication Attempts, Insufficient Session Expiration, Insufficiently Protected Credentials
  • Critical Infrastructure Sectors: Energy, Transportation Systems
  • Company Headquarters Location: United Kingdom
CVE-2026-27772
EV Energy ev.energy
EV Energy
EV Energy ev.energy: vers:all/*
EV Energy did not respond to CISA's request for coordination. Contact EV Energy using their contact page here: https://www.ev.energy/en-us for more information.
3.1 9.4 CRITICAL CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:L
CVE-2026-24445
EV Energy ev.energy
EV Energy
CVE-2026-26290
EV Energy ev.energy
EV Energy
CVE-2026-25774
EV Energy ev.energy
EV Energy
  • Khaled Sarieddine and Mohammad Ali Sayed reported these vulnerabilities to CISA
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-057-07
