FUJIFILM Healthcare Americas Synapse Mobility
  • CVSS v4 5.3
  • Vendor: FUJIFILM Healthcare Americas Corporation
  • Equipment: Synapse Mobility
  • Vulnerability: External Control of Assumed-Immutable Web Parameter
Successful exploitation of this vulnerability could allow an attacker to access information beyond their assigned roles.
The following versions of FUJIFILM Healthcare Americas Synapse Mobility are affected:
  • Synapse Mobility: Versions prior to 8.2
3.2.1 EXTERNAL CONTROL OF ASSUMED-IMMUTABLE WEB PARAMETER CWE-472
FUJIFILM Healthcare Americas Synapse Mobility versions prior to 8.2 contains a privilege escalation vulnerability through external control of Web parameter. Exploitation of this vulnerability could allow an attacker to bypass authentication and access information beyond role-based access controls.
CVE-2025-54551 has been assigned to this vulnerability. A CVSS v3.1 base score of 4.3 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:L/UI:N/S:U/C:L/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-54551. A base score of 5.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:L/UI:N/VC:L/VI:N/VA:N/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Healthcare and Public Health
Christopher Alejandro (Moroco) reported this vulnerability to CISA.
FUJIFILM Healthcare Americas has released the following mitigation options for users to follow:
  • It is recommended to upgrade to the latest version of the product or any version from 8.2 and later to resolve this issue.
  • There is an immediate mitigation available of disabling the search function in the configurator settings. Access to the search function for all users can also be removed by unchecking the "Allow plain text accession number" check box in the security section of the admin interface. This will limit the site to use of the product only via the SecureURL feature.
  • Patches have been released which will remediate the vulnerability for software versions 8.0-8.1.1.
FUJIFILM Healthcare Americas strongly encourages users to update the Synapse Mobility application to the latest version if they are past their end of support date.
For more information, refer to Synapse Mobility Vulnerability Notification.
  • August 21, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-medical-advisories/icsma-25-233-01
