Grassroots DICOM (GDCM)
  • CVSS v4 6.8
  • Vendor: Grassroots
  • Equipment: DICOM (GDCM)
  • Vulnerability: Out-of-bounds Write
Successful exploitation of this vulnerability could allow an attacker to craft a malicious DICOM file and, if opened, could crash the application resulting in a denial-of-service condition.
The following open source products and specified components are affected:
  • Grassroots DICOM (GDCM): Versions 3.0.24 and prior
  • SimpleITK: Versions 2.5.2 and prior
  • medInria: Versions 4.0 and prior
An out-of-bounds write vulnerability exists in the Grassroots DICOM library (GDCM). The issue is triggered during parsing of a malformed DICOM file containing encapsulated PixelData fragments (compressed image data stored as multiple fragments). This vulnerability leads to a segmentation fault caused by an out-of-bounds memory access due to unsigned integer underflow in buffer indexing. It is exploitable via file input, simply opening a crafted malicious DICOM file is sufficient to trigger the crash, resulting in a denial-of-service condition.
CVE-2025-11266 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.6 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:L/I:L/A:H).
A CVSS v4 score has also been calculated for CVE-2025-11266. A base score of 6.8 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:A/VC:L/VI:L/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Healthcare and Public Health
Morgen Malinoski reported this vulnerability to CISA.
The maintainer of the software recommends users update Grassroots DICOM (GDCM) to v3.2.2 or later from the main GitHub repository.
SimpleITK and medInria have both released fixes for the vulnerability.
  • December 11, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-medical-advisories/icsma-25-345-01
