Hitachi Energy RTU500 Series
  • CVSS v4 8.2
  • Vendor: Hitachi Energy
  • Equipment: RTU500 series
  • Vulnerabilities: NULL Pointer Dereference, Improper Validation of Integrity Check Value, Improper Restriction of XML External Entity Reference, Heap-based Buffer Overflow, Integer Overflow or Wraparound, Improper Restriction of Recursive Entity References in DTDs ('XML Entity Expansion'), Stack-based Buffer Overflow
Successful exploitation of these vulnerabilities could cause a Denial-of-Service condition in RTU500 devices.
Hitachi Energy reports that the following products are affected:
  • Hitachi Energy RTU500 series: Version 13.6.1 (CVE-2023-2953, CVE-2025-39203, CVE-2025-6021)
  • Hitachi Energy RTU500 series: Versions 12.7.1 through 12.7.7 (CVE-2023-2953, CVE-2025-39203, CVE-2025-6021)
  • Hitachi Energy RTU500 series: Versions 13.4.1 through 13.4.4 (CVE-2025-39203)
  • Hitachi Energy RTU500 series: Versions 13.5.1 through 13.5.3 (CVE-2023-2953, CVE-2025-39203, CVE-2025-6021)
  • Hitachi Energy RTU500 series: Versions 13.7.1 through 13.7.6
3.2.1 NULL POINTER DEREFERENCE CWE-476
A vulnerability has been identified in the openLDAP library used in Central Account Management (CAM) client. This issue can lead to a Denial of Service (DoS) condition when a specially crafted request may cause a null pointer to dereference, resulting in affected CMU to automatically recovering itself by rebooting.
CVE-2023-2953 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2023-2953. A base score of 8.2 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:P/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
3.2.2 IMPROPER VALIDATION OF INTEGRITY CHECK VALUE CWE-354
A vulnerability exists in the IEC 61850 protocol of the RTU500 product series. An IEC 61850-8 crafted message content from a device (e.g. an IED) or remote system can cause a Denial of Service (DoS) resulting in disconnection of the device to the RTU 500 until next reboot.
CVE-2025-39203 has been assigned to this vulnerability. A CVSS v3.1 base score of 4.3 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:N/A:L).
A CVSS v4 score has also been calculated for CVE-2025-39203. A base score of 5.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:N/VI:N/VA:L/SC:N/SI:N/SA:N).
3.2.3 IMPROPER RESTRICTION OF XML EXTERNAL ENTITY REFERENCE CWE-611
A vulnerability has been identified in the libexpat library used in IEC 61850 client and server components of the RTU500 product series. An authenticated and authorized malicious user could load a crafted XML input which may lead to memory mismanagement potentially causing RTU500 to reboot.
CVE-2024-45490 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2024-45490. A base score of 7.1 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
3.2.4 HEAP-BASED BUFFER OVERFLOW CWE-122
A vulnerability has been identified in libexpat library used in the IEC 61850 client and server components of the RTU500 product series. An authenticated and authorized malicious user could load a crafted XML input which may lead to heap corruption potentially causing RTU500 to reboot.
CVE-2024-45491 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2024-45491. A base score of 7.1 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
3.2.5 INTEGER OVERFLOW OR WRAPAROUND CWE-190
A vulnerability has been identified in libexpat library used in the IEC 61850 client and server components of the RTU500 product series. An authenticated and authorized malicious user could load a crafted XML input which leads to an integer overflow potentially causing RTU500 to reboot.
CVE-2024-45492 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2024-45492. A base score of 7.1 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
3.2.6 IMPROPER RESTRICTION OF RECURSIVE ENTITY REFERENCES IN DTDS ('XML ENTITY EXPANSION') CWE-776
A vulnerability has been identified in libexpat library used in the IEC 61850 client and server components of the RTU500 product series. An authenticated and authorized malicious user could load a crafted XML input which may lead to a memory mismanagement potentially causing RTU500 to reboot.
CVE-2024-28757 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2024-28757. A base score of 7.1 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
3.2.7 STACK-BASED BUFFER OVERFLOW CWE-121
A vulnerability exists in libxml library used by RTU500 Web server functionality. An authenticated and authorized malicious user could send a crafted XML message which may lead to buffer overflow potentially causing RTU500 to reboot.
CVE-2025-6021 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-6021. A base score of 6.9 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:P/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
  • COMPANY HEADQUARTERS LOCATION: Switzerland
Hitachi Energy reported these vulnerabilities to CISA.
Hitachi Energy has identified the following specific workarounds and mitigations users can apply to reduce risk:
  • (CVE-2023-2953, CVE-2025-39203, CVE-2025-6021) RTU500 series CMU Firmware version 12.7.1 – 12.7.7: Update to CMU Firmware version 12.7.8 when available
  • (CVE-2023-2953, CVE-2025-39203, CVE-2025-6021) RTU500 series CMU Firmware version 13.5.1 – 13.5.3: Update to CMU Firmware version 13.5.4
  • (CVE-2023-2953, CVE-2025-39203, CVE-2025-6021) RTU500 series CMU Firmware version 13.6.1: Update to CMU Firmware version 13.6.3
  • (CVE-2023-2953) RTU500 series CMU Firmware version 12.7.1 – 12.7.7: Follow general mitigation factors /workarounds
  • (CVE-2023-2953, CVE-2025-39203) RTU500 series CMU Firmware version 13.6.1, RTU500 series CMU Firmware version 13.5.1 – 13.5.3, RTU500 series CMU Firmware version 13.7.1 – 13.7.6: Follow general mitigation factors/workarounds.
  • (CVE-2023-2953, CVE-2024-45490, CVE-2024-45491, CVE-2024-45492, CVE-2024-28757, CVE-2025-6021) RTU500 series CMU Firmware version 13.7.1 – 13.7.6: Update to CMU Firmware version 13.7.7
  • (CVE-2025-39203) RTU500 series CMU Firmware version 12.7.1 – 12.7.7: Follow general mitigation factors/ workarounds.
  • (CVE-2025-39203) RTU500 series CMU Firmware version 13.4.1 – 13.4.4, RTU500 series CMU Firmware version 13.7.1 – 13.7.6: Update to CMU Firmware version 13.7.7
  • (CVE-2025-39203) RTU500 series CMU Firmware version 13.4.1 – 13.4.4: Follow General Mitigation Factors/Workarounds.
  • (CVE-2024-45490, CVE-2024-45491, CVE-2024-45492, CVE-2024-28757) RTU500 series CMU Firmware version 13.7.1 – 13.7.6: Follow general mitigation factors/workarounds.
  • (CVE-2025-6021) RTU500 series CMU Firmware version 13.6.1, RTU500 series CMU Firmware version 12.7.1 – 12.7.7, RTU500 series CMU Firmware version 13.5.1 – 13.5.3, RTU500 series CMU Firmware version 13.7.1 – 13.7.6: Follow general mitigation factors/workarounds.
For more information see the associated Hitachi Energy PSIRT security advisory 8DBD000220 Multiple Vulnerabilities in Hitachi Energy's RTU500 series Product.
  • September 16, 2025: Initial Republication of Hitachi Energy PSIRT 8DBD000220
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-259-02
