IDIS ICM Viewer
  • Vendor: IDIS
  • Equipment: ICM Viewer
  • Vulnerability: Improper Neutralization of Argument Delimiters in a Command ('Argument Injection')
Successful exploitation of this vulnerability could result in an attacker executing arbitrary code.
The following version of ICM Viewer is affected:
  • ICM Viewer: Version v1.6.0.10
3.2.1 IMPROPER NEUTRALIZATION OF ARGUMENT DELIMITERS IN A COMMAND ('ARGUMENT INJECTION') CWE-88
An argument injection vulnerability exists in the affected product that could allow an attacker to execute arbitrary code within the context of the host machine.
CVE-2025-12556 has been assigned to this vulnerability. A CVSS v3 base score of 8.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-12556. A base score of 8.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Communications
  • COMPANY HEADQUARTERS LOCATION: South Korea
Vera Mens and Noam Moshe of Claroty Team82 reported this vulnerability to CISA.
IDIS recommends users to follow these guidelines:
  • For users who continue to use the ICM Viewer:
    • You must access https://icm.idisglobal.com and follow the instructions provided to upgrade to version v1.7.1. IDIS requires all users to upgrade to v1.7.1. Failure to do so will render the ICM Viewer unusable.
  • For users who do not use the ICM Viewer:
    • You must immediately uninstall the program from your system.
  • November 04, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-308-05
