International Standards Organization ISO 15118-2
  • CVSS v4 7.2
  • Standard: ISO 15118-2 Network and Application Protocol Requirements
  • Equipment: EV Car Chargers
  • Vulnerability: Improper Restriction of Communication Channel to Intended Endpoints
Successful exploitation of this vulnerability could result in man-in-the-middle attacks.
The following ISO 15118 part is affected:
  • ISO 15118 standard: Part 15118-2 Network and Application Protocol Requirements
3.2.1 IMPROPER RESTRICTION OF COMMUNICATION CHANNEL TO INTENDED ENDPOINTS CWE-923
By manipulating the Signal Level Attenuation Characterization (SLAC) protocol with spoofed measurements, an attacker can stage a man-in-the-middle attack between an electric vehicle and chargers that comply with the ISO 15118-2 part. This vulnerability may be exploitable wirelessly, within close proximity, via electromagnetic induction.
CVE-2025-12357 has been assigned to this vulnerability. A CVSS v3 base score of 8.3 has been calculated; the CVSS vector string is (AV:A/AC:L/PR:N/UI:N/S:U/C:H/I:L/A:H).
A CVSS v4 score has also been calculated for CVE-2025-12357. A base score of 7.2 has been calculated; the CVSS vector string is (AV:A/AC:L/AT:N/PR:N/UI:N/VC:H/VI:L/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Transportation
  • COMPANY HEADQUARTERS LOCATION: Switzerland
Mark I. Johnson of Southwest Research Institute reported this vulnerability to CISA.
ISO recommends using TLS for all communications in accordance with ISO 15118-20. While the use of TLS is recommended in ISO 15118-2, it is required in the ISO 15118-20 revision. TLS should be implemented with certificate chaining.
For additional information, please contact the International Electrotechnical Commission.
  • October 30, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-303-01
