Johnson Controls, Inc. Frick Controls Quantum HD
Successful exploitation of these vulnerabilities can lead to pre-authentication remote code execution, information leak or denial of service.
The following versions of Johnson Controls, Inc. Frick Controls Quantum HD are affected:
  • Frick Controls Quantum HD <=10.22 (CVE-2026-21654, CVE-2026-21656, CVE-2026-21657, CVE-2026-21658, CVE-2026-21659, CVE-2026-21660)
v3 9.1 Johnson Controls, Inc. Johnson Controls, Inc. Frick Controls Quantum HD Improper Neutralization of Special Elements used in an OS Command ('OS Command Injection'), Improper Control of Generation of Code ('Code Injection'), Relative Path Traversal, Plaintext Storage of a Password
  • Critical Infrastructure Sectors: Food and Agriculture
  • Company Headquarters Location: Ireland
CVE-2026-21654
The Frick Controls Quantum HD is vulnerable due to insufficient validation of input in certain parameters that may permit unexpected actions, which could impact the security of the device before authentication occurs.
Johnson Controls, Inc. Frick Controls Quantum HD: <=10.22
The Frick Controls Quantum HD, versions 10.22 through 11, are legacy platforms that have reached end of support. Johnson Controls, Inc. recommends upgrading to the latest platform, Quantum HD Unity, version 12 or higher. The update procedure can be found here (https://frickcontrolsblob.file.core.windows.net/frickweb1/Quantum-HD-Unity/Quantum_HD_Unity_Software_Update_Procedure.pdf?sv=2018-03-28&si=frickweb1-174C1294FA7&sr=f&sig=us0dhk6IWmCvmDvBs02yJvC%2BjnzbxqZmb4QEpVVDkxY%3D).
After completing the upgrade to version 12, verify full compliance with the hardening guide and apply all recommended security configurations.
For more detailed mitigation instructions, please see Johnson Controls Product Security Advisory JCI-PSA-2026-05 at https://www.johnsoncontrols.com/trust-center/cybersecurity/security-advisories.
3.1 9.1 CRITICAL CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:H/A:H
CVE-2026-21656
CVE-2026-21657
CVE-2026-21658
CVE-2026-21659
The Frick Controls Quantum HD contains a vulnerability that allows an unauthenticated attacker to execute arbitrary code on the affected device, leading to full system compromise.
Relevant CWE: CWE-23 Relative Path Traversal
3.1 7.5 HIGH CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N
CVE-2026-21660
Hardcoded credentials in the Frick Controls Quantum HD create a vulnerability that leads to unauthorized access, exposure of sensitive information, and potential misuse or system compromise.
Relevant CWE: CWE-256 Plaintext Storage of a Password
3.1 6.2 MEDIUM CVSS:3.1/AV:L/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N
  • Noam Moshe of Claroty Research Team 82 reported these vulnerabilities to CISA
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-057-01
