Mitsubishi Electric Iconics Digital Solutions and Mitsubishi Electrics Products
Successful exploitation of this vulnerability could result in denial-of-service (DoS), information tampering, and information disclosure.
The following versions of Mitsubishi Electric Iconics Digital Solutions and Mitsubishi Electrics Products are affected:
  • GENESIS64 (CVE-2025-11774)
  • ICONICS Suite (CVE-2025-11774)
  • MobileHMI (CVE-2025-11774)
  • MC Works64 (CVE-2025-11774)
v3 8.2 Mitsubishi Electric Iconics Digital Solutions, Mitsubishi Electric Mitsubishi Electric Iconics Digital Solutions and Mitsubishi Electrics Products Improper Neutralization of Special Elements used in an OS Command ('OS Command Injection')
  • Company Headquarters Location: Japan, United States
CVE-2025-11774
Malicious code execution vulnerability exists in the software keyboard function (hereinafter referred to as "keypad function") of ICONICS Suite, GENESIS64, MobileHMI, and MC Works64, which could lead to denial-of-service (DoS), information tampering, and information disclosure. An attacker may be able to execute arbitrary executable files (EXE) when a legitimate user uses the keypad function by tampering with the configuration file for the keypad function. This could allow the attacker to disclose, tamper with, delete, or destroy information stored on the PC where the affected produc is installed, or cause a denial-of-service (DoS) condition on the system, through the execution of the EXE.
Mitsubishi Electric Iconics Digital Solutions, Mitsubishi Electric GENESIS64: <=10.97.2_CFR_3, Mitsubishi Electric Iconics Digital Solutions, Mitsubishi Electric ICONICS Suite: <=10.97.2_CFR_3, Mitsubishi Electric Iconics Digital Solutions, Mitsubishi Electric MobileHMI: <=10.97.2_CFR_3, Mitsubishi Electric Iconics Digital Solutions, Mitsubishi Electric MC Works64: vers:all/*
Mitsubishi Electric Iconics Digital Solutions recommends users of GENESIS64, IONICS Suite, or MobileHMI upgrade to the GENESIS64 v10.97.3 or higher, or upgrade to the latest product, GENESIS V11, which all contain the fix for this vulnerability.
Version 10.97.3 can be downloaded by accessing Community Portal (https://iconicsinc.my.site.com/community) and navigating to "Resources > Product Downloads > 10.97.3."
The latest patch version for GENESIS64 Version 10.97.3 can be downloaded from the link below:
https://iconicsinc.my.site.com/community/s/software-update/a35QQ000000y2oXYAQ/10973-critical-fixes-rollup-2
There are no plans to release a fixed version of MC Works64. Mitsubishi Electric recommends users of MC Works64 upgrade to the GENESIS64 v10.97.3 or higher.
Mitsubishi Electric Iconics Digital Solutions and Mitsubishi Electric recommends users take the following mitigations to minimize the risk of exploiting this vulnerability:
Use the PCs with the affected product installed in the LAN and block remote login from untrusted networks, hosts and users.
Block unauthorized access by using a firewall or virtual private network (VPN), etc., and allow remote login only to trusted users when connecting the PCs with the affected product installed to the Internet.
Restrict physical access to the PC with the affected product installed and the network to which the PC is connected to prevent unauthorized physical access.
Do not click web links in emails from untrusted sources. Also, do not open attachments in untrusted emails.
Install an antivirus software in the PC with the affected product installed.
Refer to the Mitsubishi Electric Iconics Digital Solutions Whitepaper on Security Vulnerabilities, the most recent version of which can be found at: https://iconics.com/About/Security/CERT
Refer to the Mitsubishi Electric security advisory at: https://www.mitsubishielectric.com/psirt/vulnerability/pdf/2025-018_en.pdf for information on the availability of the security updates.
3.1 8.2 HIGH CVSS:3.1/AV:L/AC:L/PR:L/UI:R/S:C/C:H/I:H/A:H
  • Mitsubishi Electric Iconics Digital Solutions reported this vulnerability to CISA
  • Initial Release Date: 2025-12-18
2025-12-18 1 Initial Republication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-352-04
