Mitsubishi Electric MELSEC iQ-F Series EtherNet/IP module and Ethernet module
Successful exploitation of these vulnerabilities could allow a remote attacker to cause a denial-of-service condition by continuously sending UDP packets to the affected products.
The following versions of Mitsubishi Electric MELSEC iQ-F Series EtherNet/IP module and Ethernet module are affected:
  • MELSEC iQ-F Series FX5-ENET/IP Ethernet Module FX5-ENET/IP <=1.106, vers:all/* (CVE-2026-1874, CVE-2026-1876)
  • MELSEC iQ-F Series FX5-EIP EtherNet/IP Module FX5-EIP vers:all/* (CVE-2026-1874, CVE-2026-1875)
v3 7.5 Mitsubishi Electric Mitsubishi Electric MELSEC iQ-F Series EtherNet/IP module and Ethernet module Always-Incorrect Control Flow Implementation, Improper Resource Shutdown or Release
  • Company Headquarters Location: Japan
CVE-2026-1874
An always-incorrect control flow implementation vulnerability may allow a remote attacker to cause a denial-of-service condition by continuously sending UDP packets to the affected products.
Mitsubishi Electric
Mitsubishi Electric MELSEC iQ-F Series FX5-ENET/IP Ethernet Module FX5-ENET/IP: <=1.106, Mitsubishi Electric MELSEC iQ-F Series FX5-EIP EtherNet/IP Module FX5-EIP: vers:all/*
Users of FX5-ENET/IP versions 1.106 and prior should download the update file for version 1.107 or later and apply it. The update file is available at: https://www.mitsubishielectric.com/fa/download/index.html.
The fixed version for the FX5-EIP is scheduled to be released in the near future. In the meantime, users should apply mitigations or workarounds.
For users of products that do not have a fixed version or who cannot immediately update the product, Mitsubishi Electric recommends using a firewall, virtual private network (VPN), etc. and preventing unauthorized access when internet access is required, to minimize the risk of exploiting this vulnerability.
For users of products that do not have a fixed version or who cannot immediately update the product, Mitsubishi Electric recommends using the affected product within a LAN and blocking access from untrusted networks and hosts through firewalls, to minimize the risk of exploiting this vulnerability.
For users of products that do not have a fixed version or who cannot immediately update the product, Mitsubishi Electric recommends using the IP filter function of the affected product and blocking access from untrusted hosts, to minimize the risk of exploiting this vulnerability. For details on the IP filter function, refer to “13.1 IP Filter Function” in the MELSEC iQ-F FX5 User’s Manual (Communication).
For users of products that do not have a fixed version or who cannot immediately update the product, Mitsubishi Electric recommends restricting physical access to the affected product, as well as to PCs and network devices to which it is connected, to minimize the risk of exploiting this vulnerability.
For users of products that do not have a fixed version or who cannot immediately update the product, Mitsubishi Electric recommends installing anti-virus software on PCs that can access the affected product, to minimize the risk of exploiting this vulnerability.
For more information, see Mitsubishi Electric 2025-021. https://www.mitsubishielectric.com/psirt/vulnerability/pdf/2025-021_en.pdf
Relevant CWE: CWE-670 Always-Incorrect Control Flow Implementation
CVE-2026-1875
An improper resource shutdown or release vulnerability in the affected products may allow a remote attacker to cause a denial-of-service condition by continuously sending UDP packets.
Mitsubishi Electric
Relevant CWE: CWE-404 Improper Resource Shutdown or Release
CVE-2026-1876
An improper resource shutdown or release vulnerability may allow a remote attacker to cause a denial-of-service condition in the affected products by continuously sending UDP packets.
Mitsubishi Electric
Mitsubishi Electric MELSEC iQ-F Series FX5-ENET/IP Ethernet Module FX5-ENET/IP: vers:all/*
No fix planned
Users should apply mitigations or workarounds since there are no plans to release a fixed version.
For users of products that do not have a fixed version, Mitsubishi Electric recommends using a firewall, virtual private network (VPN), etc. and preventing unauthorized access when internet access is required, to minimize the risk of exploiting this vulnerability.
For users of products that do not have a fixed version, Mitsubishi Electric recommends using the affected product within a LAN and blocking access from untrusted networks and hosts through firewalls, to minimize the risk of exploiting this vulnerability.
For users of products that do not have a fixed version, Mitsubishi Electric recommends using the IP filter function of the affected product and blocking access from untrusted hosts, to minimize the risk of exploiting this vulnerability. For details on the IP filter function, refer to “13.1 IP Filter Function” in the MELSEC iQ-F FX5 User’s Manual (Communication).
For users of products that do not have a fixed version, Mitsubishi Electric recommends restricting physical access to the affected product, as well as to PCs and network devices to which it is connected, to minimize the risk of exploiting this vulnerability.
For users of products that do not have a fixed version, Mitsubishi Electric recommends installing anti-virus software on PCs that can access the affected product, to minimize the risk of exploiting this vulnerability.
  • Mitsubishi Electric reported these vulnerabilities to CISA
This product is provided subject to this notification (https://www.cisa.gov/notification) and this privacy & use policy (https://www.cisa.gov/privacy-policy).
CISA recommends users take defensive measures to minimize the risk of exploitation of these vulnerabilities. CISA reminds organizations to perform proper impact analysis and risk assessment prior to deploying defensive measures.
This ICSA is a republication of Mitsubishi Electric security advisory "2025-021 Multiple denial-of-service vulnerabilities in Ethernet function of MELSEC iQ-F Series EtherNet/IP module and Ethernet module" from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact CISA directly for any questions regarding this advisory.
  • Initial Release Date: 2026-03-03
2026-03-03 1 Initial Publication
2026-03-03 2 Initial CISA Republication of Mitsubishi Electric security advisory 2025-021
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-62-01
