Mobility46 mobility46.se
The following versions of Mobility46 mobility46.se are affected:
  • mobility46.se vers:all/* (CVE-2026-27028, CVE-2026-26305, CVE-2026-27647, CVE-2026-22878)
v3 9.4 Mobility46 Mobility46 mobility46.se Missing Authentication for Critical Function, Improper Restriction of Excessive Authentication Attempts, Insufficient Session Expiration, Insufficiently Protected Credentials
  • Critical Infrastructure Sectors: Energy, Transportation Systems
  • Company Headquarters Location: Sweden
CVE-2026-27028
Mobility46
Mobility46 mobility46.se: vers:all/*
Mobility46 did not respond to CISA's request for coordination. Contact Mobility46 using their contact page here: https://www.mobility46.se/en/contact-us for more information.
3.1 9.4 CRITICAL CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:L
CVE-2026-26305
Mobility46
CVE-2026-27647
Mobility46
CVE-2026-22878
Mobility46
  • Khaled Sarieddine and Mohammad Ali Sayed reported these vulnerabilities to CISA
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-057-08
