NIHON KOHDEN Central Monitor CNS-6201
  • Vendor: NIHON KOHDEN
  • Equipment: Central Monitor CNS-6201
  • Vulnerability: NULL Pointer Dereference
Successful exploitation of this vulnerability could allow an attacker to cause a denial-of-service condition.
The following NIHON KOHDEN products are affected:
  • Central Monitor CNS-6201: Versions 01-03
  • Central Monitor CNS-6201: Versions 01-04
  • Central Monitor CNS-6201: Versions 01-05
  • Central Monitor CNS-6201: Versions 01-06
  • Central Monitor CNS-6201: Versions 02-10
  • Central Monitor CNS-6201: Versions 02-11
  • Central Monitor CNS-6201: Versions 02-40
3.2.1 NULL POINTER DEREFERENCE CWE-476
In the affected versions of the CNS-6201 central monitor, if an attacker sends a specially crafted UDP packet, a NULL pointer dereference occurs during the receiving process, causing the process to terminate abnormally and resulting in a denial-of-service (DoS) condition. Exploiting this vulnerability does not require authentication, and it can be reproduced as long as the UDP service is reachable on the network.
CVE-2025-59668 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-59668. A base score of 8.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Healthcare and Public Health
Jared P. Quinn of QuinnTech.ai reported the vulnerability to NIHON KOHDEN.
The vulnerability identified in this advisory affects versions that are no longer supported. For the Central Monitor CNS-6201, maintenance support in the United States ended in September 2024 (EOS), and maintenance support for the relevant versions has already ended in other countries as well. NIHON KOHDEN recommends users migrate to successor products.
If users choose to continue using the CNS-6201 product, ensure the following supplementary controls are strictly implemented under the supervision of a network administrator:
  • Isolate the affected products from the Internet and any untrusted systems.
  • Monitor all network traffic attempting to reach the affected products and log any suspicious activity.
  • If integration with systems such as a Hospital Information System (HIS) is necessary, establish a boundary device (firewall or router) between the physically separated monitoring network and other networks, and explicitly allow only the minimum necessary communications.
  • Ensure monitoring redundancy by using a bedside monitor or medical telemetry system to establish an alternate network connection.
For more information, refer to the NIHON KOHDEN product security portal.
  • October 23, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-medical-advisories/icsma-25-296-01
