Portwell Engineering Toolkits
Successful exploitation of this vulnerability could allow a local attacker to escalate privileges or cause a denial-of-service condition.
The following versions of Portwell Engineering Toolkits are affected:
  • Portwell Engineering Toolkits 4.8.2
v3 8.8 Portwell Portwell Engineering Toolkits Improper Restriction of Operations within the Bounds of a Memory Buffer
  • Critical Infrastructure Sectors: Critical Manufacturing, Energy
  • Company Headquarters Location: Taiwan
CVE-2026-3437
An Improper Restriction of Operations within the Bounds of a Memory Buffer vulnerability in Portwell Engineering Toolkits version 4.8.2 could allow a local authenticated attacker to read and write to arbitrary memory via the Portwell Engineering Toolkits driver. Successful exploitation of this vulnerability could result in escalation of privileges or cause a denial-of-service condition.
Portwell
Portwell Portwell Engineering Toolkits: 4.8.2
Portwell has not responded to requests to work with CISA to mitigate this vulnerability. Users of affected versions of Portwell Engineering Toolkits are invited to contact Portwell customer support (https://portwell.com/support.php) for additional information.
Relevant CWE: CWE-119 Improper Restriction of Operations within the Bounds of a Memory Buffer
3.1 8.8 HIGH CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:C/C:H/I:H/A:H
  • Jason Huang of Cyber Threat & Product Defense Center of TXOne Networks Inc. reported this vulnerability to CISA
  • Initial Release Date: 2026-03-03
2026-03-03 1 Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-062-04
