- CVSS v4 8.6
- Vendor: Rockwell Automation
- Equipment: AADvance-Trusted SIS Workstation
- Vulnerability: Path Traversal
Successful exploitation of this vulnerability may allow remote code execution.
Rockwell Automation reports the following versions of AADvance-Trusted SIS Workstation, a software suite for developing and managing safety instrumented system (SIS) applications, are affected:
- AADvance-Trusted SIS Workstation: Versions 2.00.00 to 2.00.04
3.2.1 Improper Limitation of a Pathname to a Restricted Directory ('Path Traversal') CWE-22
A directory traversal vulnerability in DotNetZip v.1.16.0 and earlier may allow a remote attacker to execute arbitrary code via the src/Zip.Shared/ZipEntry.Extract.cs component. Exploitation requires the victim to open a malicious file.
CVE-2024-48510 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2024-48510. A base score of 8.6 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Rockwell Automation reports this issue is corrected in software Version 2.01.00 and later.
For more information about this issue, see the advisory on the Rockwell Automation security page.
Users of the affected software who are unable to upgrade to one of the corrected versions should follow Rockwell Automation security best practices.
If you have any questions regarding the security issue above and how to mitigate it, contact TechConnect for assistance. More information can be found at Contact Us | Rockwell Automation | US.
- When remote access is required, use more secure methods, such as virtual private networks (VPNs), recognizing VPNs may have vulnerabilities and should be updated to the most current version available. Also recognize VPN is only as secure as the connected devices.
- November 13, 2025: Initial Republication of Rockwell Automation
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-317-10
