Rockwell Automation CompactLogix 5370
Successful exploitation of this vulnerability could allow an attacker to cause a denial-of-service condition.
The following versions of Rockwell Automation CompactLogix 5370 are affected:
  • CompactLogix 5370 (CVE-2025-11743)
v3 6.5 Rockwell Automation Rockwell Automation CompactLogix 5370 Improper Validation of Specified Quantity in Input
CVE-2025-11743
The affected product is vulnerable to a denial-of-service issue. The security issue occurs when a malformed CIP forward open message is sent. This could result in a major nonrecoverable fault, which would require a restart to recover.
Rockwell Automation
Rockwell Automation CompactLogix 5370: <=34.013, Rockwell Automation CompactLogix 5370: <=35.012, Rockwell Automation CompactLogix 5370: 36.011
Rockwell Automation reports that the following versions are fixed:
Versions 37.011 and later
Version 34.016
Version 35.015
Version 36.012
Users using the affected software, who are not able to upgrade to one of the corrected versions, should use our security best practices.
For additional details, refer to advisory SD1770 on the Rockwell Automation security page.
Relevant CWE: CWE-1284 Improper Validation of Specified Quantity in Input
3.1 6.5 MEDIUM CVSS:3.1/AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H
  • Rockwell Automation reported this vulnerability to CISA
  • Initial Release Date: 2026-01-22
2026-01-22 1 Initial Republication of Rockwell Automation SD1770
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-022-03
