Rockwell Automation FactoryTalk DataMosaix Private Cloud
  • CVSS v4 8.6
  • Equipment: FactoryTalk DataMosaix Private Cloud
  • Vulnerabilities: Weak Authentication, Improper Encoding or Escaping of Output
Successful exploitation of these vulnerabilities could allow an attacker to take over accounts, steal credentials, redirect users to a malicious website, or bypass MFA.
The following versions of FactoryTalk DataMosaix Private Cloud are affected:
  • FactoryTalk DataMosaix Private Cloud: Versions 7.11, 8.00, 8.01 (CVE-2025-11084)
  • FactoryTalk DataMosaix Private Cloud: Versions 7.11, 8.00 (CVE-2025-11085)
3.2.1 WEAK AUTHENTICATION CWE-1390
A security issue exists within DataMosaix™ Private Cloud, allowing attackers to bypass MFA during setup and obtain a valid login-token cookie without knowing the users password. This vulnerability occurs when MFA is enabled but not completed within a 7-day period.
CVE-2025-11084 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.8 has been calculated; the CVSS vector string is (AV:A/AC:H/PR:N/UI:N/S:U/C:H/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-11084. A base score of 7.6 has been calculated; the CVSS vector string is (AV:A/AC:H/AT:N/PR:N/UI:N/VC:H/VI:H/VA:N/SC:N/SI:N/SA:N).
3.2.2 IMPROPER ENCODING OR ESCAPING OF OUTPUT CWE-116
A security issue exists within DataMosaix™ Private Cloud allowing for Persistent cross-site scripting. This vulnerability can result in the execution of malicious JavaScript, allowing for account takeover, credential theft, or redirection to a malicious website.
CVE-2025-11085 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.0 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:L/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-11085. A base score of 8.6 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:L/UI:P/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Rockwell Automation encourages users of the affected software to apply the following risk mitigations, if possible:
  • For CVE-2025-11084: Update FactoryTalk DataMosaix Private Cloud to Version 8.02
  • For CVE-2025-11085: Update FactoryTalk DataMosaix Private Cloud to Version 8.01
Users using the affected software, who are not able to upgrade to one of the corrected versions, should use Rockwell Automation's best security practices.
  • November 13, 2025: Initial Republication of Rockwell Automation advisory 'FactoryTalk DataMosaix Private Cloud – Multiple Vulnerabilities'
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-317-07
