Successful exploitation of this vulnerability could allow an attacker to perform unauthorized sensitive database operations.
The following versions of Rockwell Automation FactoryTalk DataMosaix Private Cloud are affected:
- FactoryTalk DataMosaix Private Cloud (CVE-2025-12807)
| v3 8.8 | Rockwell Automation | Rockwell Automation FactoryTalk DataMosaix Private Cloud | Improper Neutralization of Special Elements used in an SQL Command ('SQL Injection') |
CVE-2025-12807
A security issue was discovered in DataMosaix Private Cloud, allowing users with low privilege to perform sensitive database operations through exposed Application Programming Interface (API) endpoints.
Rockwell Automation
Rockwell Automation FactoryTalk DataMosaix Private Cloud: 7.11, Rockwell Automation FactoryTalk DataMosaix Private Cloud: 8.00, Rockwell Automation FactoryTalk DataMosaix Private Cloud: 8.01
Rockwell Automation encourages users of the affected software to apply the following risk mitigations, if possible:
Update FactoryTalk DataMosaix Private Cloud to Version 8.01.02 or later.
Users using the affected software, who are not able to upgrade to one of the corrected versions, should use Rockwell Automation's best security practices.
Relevant CWE: CWE-89 Improper Neutralization of Special Elements used in an SQL Command ('SQL Injection')
| 3.1 | 8.8 | HIGH | CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H |
- Rockwell Automation reported this vulnerability to CISA
- Initial Release Date: 2026-01-13
| 2026-01-13 | 1 | Initial republication of Rockwell Automation advisory 'FactoryTalk DataMosaix Private Cloud SQL Injection' |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-013-02
