- CVSS v4 8.4
- Vendor: Rockwell Automation
- Equipment: Verve Asset Manager
- Vulnerability: Incorrect Authorization
Successful exploitation of this vulnerability could result in an attacker accessing or altering user data.
The following versions of Verve Asset Manager, an OT cybersecurity platform, are affected:
- Verve Asset Manager: Version 1.33
- Verve Asset Manager: Version 1.34
- Verve Asset Manager: Version 1.35
- Verve Asset Manager: Version 1.36
- Verve Asset Manager: Version 1.37
- Verve Asset Manager: Version 1.38
- Verve Asset Manager: Version 1.39
- Verve Asset Manager: Version 1.40
- Verve Asset Manager: Version 1.41
- Verve Asset Manager: Version 1.41.1
- Verve Asset Manager: Version 1.41.2
- Verve Asset Manager: Version 1.41.3
3.2.1 INCORRECT AUTHORIZATION CWE-863
A security issue was discovered within Verve Asset Manager allowing unauthorized read-only users to read, update, and delete users via the API.
CVE-2025-11862 has been assigned to this vulnerability. A CVSS v3 base score of 9.9 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:L/UI:N/S:C/C:L/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-11862. A base score of 8.4 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:L/UI:N/VC:L/VI:H/VA:H/SC:N/SI:L/SA:H).
Rockwell Automation has addressed this issue in version 1.41.4 and 1.42. Rockwell Automation encourages users to update to the newest available version.
For more information about this issue, see the advisory on the Rockwell Automation security page.
Users with additional questions can contact Rockwell Automation TechConnect for help.
- November 13, 2025: Initial Republication of Rockwell Automation advisory 'Verve Asset Manager Access Control
Vulnerability'
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-317-05
