Schneider Electric Modicon M340 Controller and Communication Modules
  • Vendor: Schneider Electric
  • Equipment: Modicon M340 and Communication Modules
  • Vulnerability: Improper Input Validation
Successful exploitation of this vulnerability could allow an attacker to cause a denial-of-service condition.
  • Modicon M340: All versions
  • BMXNOR0200H Ethernet/Serial RTU Module: All versions
  • BMXNGD0100 M580 Global Data module: All versions
  • BMXNOC0401 Modicon M340 X80 Ethernet Communication modules: All versions
  • BMXNOE0100 Modbus/TCP Ethernet Modicon M340 module: Versions prior to 3.60
  • BMXNOE0110 Modbus/TCP Ethernet Modicon M340 FactoryCast module: Versions prior to 6.80
Improper Input Validation vulnerability exists that could cause a Denial Of Service when specially crafted FTP command is sent to the device.
CVE-2025-6625 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-6625. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
CyManII reported this vulnerability to Schneider Electric.
  • BMXNOE0100 Modbus/TCP Ethernet Modicon M340 module: Version 3.60 of BMXNOE0100 includes a fix for this vulnerability and is available for download here. Reboot is needed to complete the firmware upgrade.
  • BMXNOE0110 Modbus/TCP Ethernet Modicon M340 FactoryCast module: Version 6.80 of BMXNOE0110 includes a fix for this vulnerability and is available for download here. Reboot is needed to complete the firmware upgrade.
Schneider Electric is establishing a remediation plan for all future versions of Modicon M340, BMXNOR0200H, BMXNGD0100, and BMXNOC401. Until then, users should immediately apply the following mitigations to reduce the risk of exploit:
  • FTP service is disabled by default
  • Ensure to disable FTP service when not in use
  • Setup network segmentation and implement a firewall to block all unauthorized access to ports 21/FTP
  • Use VPN (Virtual Private Networks) tunnels if remote access is required
For more information see the associated Schneider Electric CPCERT security advisory SEVD-2025-224-05.
  • August 26, 2025: Initial Republication of Schneider Electric SEVD-2025-224-05
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-238-03
