Siemens COMOS
  • CVSS v3 8.2
  • Equipment: COMOS
  • Vulnerability: Out-of-bounds Write
Successful exploitation of this vulnerability could allow an attacker to cause a crash, potentially enabling a denial-of-service attack (Crash, Exit, or Restart) or possible code execution.
  • Siemens COMOS: all versions prior to V10.6
Out-of-bounds Write vulnerability was discovered in Open Design Alliance Drawings SDK before 2025.10. Reading crafted DWF file and missing proper checks on received SectionIterator data can trigger an unhandled exception. This can allow attackers to cause a crash, potentially enabling a denial-of-service attack (Crash, Exit, or Restart) or possible code execution.
CVE-2024-8894 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.2 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:N/UI:R/S:C/C:H/I:N/A:H).
  • COMOS: Ensure all files imported into the affected product originate from a trusted source and are transmitted over secure channels
  • COMOS: Update to V10.6 or later version
For more information see the associated Siemens security advisory SSA-769791 in HTML and CSAF.
  • August 14, 2025: Initial Republication of Siemens ProductCERT SSA-769791
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-226-02
