COMOS is affected by multiple vulnerabilities that could allow an attacker to execute arbitrary code or cause denial of service condition, data infiltration or perform access control violations. Siemens has released new versions for several affected products and recommends to update to the latest versions. Siemens is preparing further fix versions and recommends countermeasures for products where fixes are not, or not yet available.
The following versions of Siemens COMOS are affected:
- COMOS V10.4 vers:intdot/<10.4.5, vers:intdot/<10.4.5 (CVE-2024-47875, CVE-2025-2783)
- COMOS V10.4.5 vers:intdot/<10.4.5.0.2 (CVE-2024-11053, CVE-2025-10148)
- COMOS V10.5 vers:intdot/<10.5.2, vers:intdot/<10.5.2 (CVE-2025-2783, CVE-2024-47875)
- COMOS V10.6 vers:all/* (CVE-2024-11053, CVE-2025-10148, CVE-2025-40800, CVE-2025-40801)
| v3 10 | Siemens | Siemens COMOS | Exposure of Sensitive Information to an Unauthorized Actor, Improper Neutralization of Input During Web Page Generation ('Cross-site Scripting'), Improper Input Validation, Generation of Predictable Numbers or Identifiers, Improper Certificate Validation |
CVE-2024-11053
When asked to both use a `.netrc` file for credentials and to follow HTTP redirects, curl could leak the password used for the first host to the followed-to host under certain circumstances. This flaw only manifests itself if the netrc file has an entry that matches the redirect target hostname but the entry either omits just the password or omits both login and password.
Siemens COMOS
COMOS V10.4.5, COMOS V10.6
None available
Currently no fix is available
Contact customer support to receive patch and update information
Relevant CWE: CWE-200 Exposure of Sensitive Information to an Unauthorized Actor
| 3.1 | 3.7 | LOW | CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:U/C:L/I:N/A:N |
CVE-2024-47875
DOMPurify is a DOM-only, super-fast, uber-tolerant XSS sanitizer for HTML, MathML and SVG. DOMpurify was vulnerable to nesting-based mXSS. This vulnerability is fixed in 2.5.0 and 3.1.3.
Siemens COMOS
COMOS V10.4, COMOS V10.5
Update to V10.4.5 or later version
Update to V10.5.2 or later version
| 3.1 | 10 | CRITICAL | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:C/C:L/I:H/A:H |
CVE-2025-2783
Incorrect handle provided in unspecified circumstances in Mojo in Google Chrome on Windows prior to 134.0.6998.177 allowed a remote attacker to perform a sandbox escape via a malicious file.
Siemens COMOS
Relevant CWE: CWE-20 Improper Input Validation
| 3.1 | 8.3 | HIGH | CVSS:3.1/AV:N/AC:H/PR:N/UI:R/S:C/C:H/I:H/A:H |
CVE-2025-10148
curl's websocket code did not update the 32 bit mask pattern for each new outgoing frame as the specification says. Instead it used a fixed mask that persisted and was used throughout the entire connection. A predictable mask pattern allows for a malicious server to induce traffic between the two communicating parties that could be interpreted by an involved proxy (configured or transparent) as genuine, real, HTTP traffic with content and thereby poison its cache. That cached poisoned content could then be served to all users of that proxy.
Siemens COMOS
None available
Relevant CWE: CWE-340 Generation of Predictable Numbers or Identifiers
| 3.1 | 5.3 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:N/A:N |
CVE-2025-40800
The IAM client in affected products is missing server certificate validation while establishing TLS connections to the authorization server. This could allow an attacker to perform a man-in-the-middle attack.
Siemens COMOS
COMOS V10.6
None available
Relevant CWE: CWE-295 Improper Certificate Validation
| 3.1 | 7.4 | HIGH | CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:U/C:H/I:H/A:N |
CVE-2025-40801
The SALT SDK is missing server certificate validation while establishing TLS connections to the authorization server. This could allow an attacker to perform a man-in-the-middle attack.
Siemens COMOS
COMOS V10.6
None available
| 3.1 | 8.1 | HIGH | CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:U/C:H/I:H/A:H |
- Siemens ProductCERT reported these vulnerabilities to CISA.
This ICSA is a verbatim republication of Siemens ProductCERT SSA-212953 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
- Initial Release Date: 2025-12-09
| 2025-12-09 | 1 | Publication Date |
| 2026-01-13 | 2 | Removed CVE-2024-11053 and CVE-2025-10148 from COMOS V10.5.2 as this version line is not affected |
| 2026-02-10 | 3 | Added fix for COMOS V10.4.5 |
| 2026-02-12 | 4 | Initial CISA Republication of Siemens ProductCERT SSA-212953 advisory |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-043-03
