- CVSS v3 8.2
- Vendor: Siemens
- Equipment: Desigo CC Product Family and SENTRON Powermanager
- Vulnerability: Least Privilege Violation
Successful exploitation of this vulnerability could allow privilege escalation.
- Desigo CC family V5.0: All versions
- Desigo CC family V5.1: All versions
- Desigo CC family V6: All versions
- Desigo CC family V7: All versions
- Desigo CC family V8: All versions
- SENTRON Powermanager V5: All versions
- SENTRON Powermanager V6: All versions
- SENTRON Powermanager V7: All versions
- SENTRON Powermanager V8: All versions
3.2.1 LEAST PRIVILEGE VIOLATION CWE-272
Wibu CodeMeter before 8.30a sometimes allows privilege escalation immediately after installation (before a logoff or reboot). For exploitation, there must have been an unprivileged installation with UAC, and the CodeMeter Control Center component must be installed, and the CodeMeter Control Center component must not have been restarted. In this scenario, the local user can navigate from Import License to a privileged instance of Windows Explorer.
CVE-2025-47809 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.2 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:H/UI:N/S:C/C:H/I:H/A:H).
Please follow below steps to update the WIBU CodeMeter :
- Uninstall the previous installed version of CodeMeter via Control Panel
- Install the CodeMeter V8.30a (Refer: https://www.wibu.com/us/support.html)
- Restart client/server after installation of CodeMeter
For more details regarding the vulnerability in CodeMeter Runtime refer to:
- WIBU Systems Security Advisory WIBU-100120: https://www.wibu.com/support/security-advisories/wibu-100120.html
For more information see the associated Siemens security advisory SSA-201595 in HTML and CSAF.
- August 19, 2025: Initial Republication of Siemens ProductCERT SSA-201595
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-231-01
