Siemens gWAP
Siemens gPROMS Web Applications Publisher (gWAP) is affected by a remote code execution vulnerability introduced through a third-party component, namely the Axios HTTP client library. The vulnerability stems from a specific "Gadget" attack chain that allows prototype pollution in other third-party libraries, potentially allowing an attacker to execute arbitrary code. Siemens has released a new version for gWAP and recommends to update to the latest version.
The following versions of Siemens gWAP are affected:
  • gWAP vers:intdot/<3.1.1
v3 8 Siemens Siemens gWAP Improper Neutralization of CRLF Sequences in HTTP Headers ('HTTP Request/Response Splitting')
CVE-2026-40175
Axios is a promise based HTTP client for the browser and Node.js. Prior to 1.15.0 and 0.3.1, the Axios library is vulnerable to a specific "Gadget" attack chain that allows Prototype Pollution in any third-party dependency to be escalated into Remote Code Execution (RCE) or Full Cloud Compromise (via AWS IMDSv2 bypass). This vulnerability is fixed in 1.15.0 and 0.3.1.
Siemens gWAP
gWAP
Update to V3.1.1 or later version
https://support.sw.siemens.com/product/284395347/
Relevant CWE: CWE-113 Improper Neutralization of CRLF Sequences in HTTP Headers ('HTTP Request/Response Splitting')
3.1 8 HIGH CVSS:3.1/AV:N/AC:H/PR:H/UI:N/S:C/C:H/I:H/A:H
This ICSA is a verbatim republication of Siemens ProductCERT SSA-876049 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
  • Initial Release Date: 2026-05-12
2026-05-12 1 Publication Date
2026-05-14 2 Initial CISA Republication of Siemens ProductCERT SSA-876049 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-134-01
