Siemens Mendix OIDC SSO
  • CVSS v4 2.1
  • Equipment: Mendix OIDC SSO
  • Vulnerability: Incorrect Privilege Assignment
Successful exploitation of this vulnerability could allow an attacker to modify the system and gain administrator read/write privileges.
Siemens reports the following products are affected:
  • Siemens Mendix OIDC SSO (Mendix 9 compatible): All versions
  • Siemens Mendix OIDC SSO (Mendix 10 compatible): All versions before V4.0.0
3.2.1 INCORRECT PRIVILEGE ASSIGNMENT CWE-266
The Mendix OIDC SSO module grants read and write access to all tokens exclusively to the Administrator role, which could result in privilege misuse by an adversary modifying the module during Mendix development.
CVE-2025-40571 has been assigned to this vulnerability. A CVSS v3.1 base score of 2.2 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:H/PR:H/UI:N/S:U/C:L/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-40571. A base score of 2.1 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:H/AT:N/PR:H/UI:N/VC:L/VI:N/VA:N/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Critical Manufacturing, Energy, Financial Services, Healthcare and Public Health, Transportation Systems
  • All affected products: The default configuration of the OIDC.Token entity is set to restrict read/write access only to the administrator role. If this setting is not restrictive enough, the option arises to change the access rule of the specific entity, or to create a different user role to handle different administrative tasks.
  • Mendix OIDC SSO (Mendix 9 compatible): Currently no fix is available.
  • Mendix OIDC SSO (Mendix 10 compatible): Update to V4.0.0 or a later version.
For more information see the associated Siemens security advisory SSA-726617 in HTML and CSAF.
May 15, 2025: Initial Republication of Siemens ProductCERT SSA-726617
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-135-15
