Siemens NX is affected by multiple file parsing vulnerabilities that could be triggered when the application reads files in CGM format. If a user is tricked to open a malicious file with any of the affected products, this could lead the application to crash or potentially lead to arbitrary code execution. Siemens has released a new version for NX and recommends to update to the latest version.
The following versions of Siemens NX are affected:
- NX vers:intdot/<2512 (CVE-2026-22923, CVE-2026-22924, CVE-2026-22925)
| v3 7.8 | Siemens | Siemens NX | Stack-based Buffer Overflow, Out-of-bounds Read |
CVE-2026-22923
The affected application contains a stack-based buffer overflow vulnerability that could be triggered while parsing specially crafted CGM files. This could allow an attacker to execute code in the context of the current process.
Siemens NX
NX
Do not open untrusted CGM files in affected applications
Update to V2512 or later version
| 3.1 | 7.8 | HIGH | CVSS:3.1/AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H |
CVE-2026-22924
The affected applications contains an out of bounds read vulnerability while parsing specially crafted CGM files. This could allow an attacker to execute code in the context of the current process.
Siemens NX
NX
CVE-2026-22925
Siemens NX
NX
- Siemens ProductCERT reported these vulnerabilities to CISA.
- Michael Heinzl reported this vulnerability to Siemens.
This ICSA is a verbatim republication of Siemens ProductCERT SSA-535115 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
| 2026-02-10 | 1 | Publication Date |
| 2026-02-12 | 2 | Initial CISA Republication of Siemens ProductCERT SSA-535115 advisory |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-043-08
