- CVSS v4 8.5
- Vendor: Siemens
- Equipment: SIMATIC S7-PLCSIM
- Vulnerability: Deserialization of Untrusted Data
Successful exploitation of this vulnerability could allow an attacker to cause a type confusion and execute arbitrary code within the affected application.
- SIMATIC S7-PLCSIM V17: All versions
- SIMOCODE ES V17: All versions
- SIMOCODE ES V18: All versions
- SIMOCODE ES V19: All versions
- SIMOCODE ES V20: All versions
- SIMOTION SCOUT TIA V5.4: All versions
- SIMOTION SCOUT TIA V5.5: All versions
- SIMOTION SCOUT TIA V5.6: All versions prior to V5.6 SP1 HF7
- SIMOTION SCOUT TIA V5.7: All versions
- SINAMICS Startdrive V17: All versions
- SINAMICS Startdrive V18: All versions
- SIMATIC STEP 7 V17: All versions
- SINAMICS Startdrive V19: All versions
- SINAMICS Startdrive V20: All versions
- SIRIUS Safety ES V17 (TIA Portal): All versions
- SIRIUS Safety ES V18 (TIA Portal): All versions
- SIRIUS Safety ES V19 (TIA Portal): All versions
- SIRIUS Safety ES V20 (TIA Portal): All versions
- SIRIUS Soft Starter ES V17 (TIA Portal): All versions
- SIRIUS Soft Starter ES V18 (TIA Portal): All versions
- SIRIUS Soft Starter ES V19 (TIA Portal): All versions
- SIRIUS Soft Starter ES V20 (TIA Portal): All versions
- SIMATIC STEP 7 V18: All versions
- TIA Portal Cloud V17: All versions
- TIA Portal Cloud V18: All versions
- TIA Portal Cloud V19: Versions prior to V5.2.1.1
- TIA Portal Cloud V20: All versions
- SIMATIC STEP 7 V19: All versions prior to V19 Update 4
- SIMATIC STEP 7 V20: All versions
- SIMATIC WinCC V17: All versions
- SIMATIC WinCC V18: All versions
- SIMATIC WinCC V19: All versions prior to V19 Update 4
- SIMATIC WinCC V20: All versions
3.2.1 DESERIALIZATION OF UNTRUSTED DATA CWE-502
Affected products do not properly sanitize stored security properties when parsing project files. This could allow an attacker to cause a type confusion and execute arbitrary code within the affected application.
CVE-2025-40759 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-40759. A base score of 8.5 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:N/UI:P/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
- All affected products: Only open projects from trusted sources.
- SIMATIC S7-PLCSIM V17: Currently no fix is planned
- SIMATIC STEP 7 V17, SIMATIC STEP 7 V18, SIMATIC STEP 7 V20, SIMATIC WinCC V17, SIMATIC WinCC V18, SIMATIC WinCC V20, SIMOCODE ES V17, SIMOCODE ES V18, SIMOCODE ES V19, SIMOCODE ES V20, SIMOTION SCOUT TIA V5.4, SIMOTION SCOUT TIA V5.5, SIMOTION SCOUT TIA V5.7, SINAMICS Startdrive V17, SINAMICS Startdrive V18, SINAMICS Startdrive V19, SINAMICS Startdrive V20, SIRIUS Safety ES V17 (TIA Portal), SIRIUS Safety ES V18 (TIA Portal), SIRIUS Safety ES V19 (TIA Portal), SIRIUS Safety ES V20 (TIA Portal), SIRIUS Soft Starter ES V17 (TIA Portal), SIRIUS Soft Starter ES V18 (TIA Portal), SIRIUS Soft Starter ES V19 (TIA Portal), SIRIUS Soft Starter ES V20 (TIA Portal), TIA Portal Cloud V17, TIA Portal Cloud V18, TIA Portal Cloud V20: Currently no fix is available
- SIMATIC STEP 7 V19, SIMATIC WinCC V19: Update to V19 Update 4 or later version
- SIMOTION SCOUT TIA V5.6: Update to V5.6 SP1 HF7 or later version
- TIA Portal Cloud V19: TIA Portal Cloud V5.2.1.1 or later version updated TIA Portal to V19 Update 4 or later version
For more information see the associated Siemens security advisory SSA-493396 in HTML and CSAF.
- August 14, 2025: Initial Republication of Siemens ProductCERT SSA-493396
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-226-11
