The SIPROTEC 5 devices do not use sufficiently random numbers to generate session identifiers. This could facilitate a brute-force attack against a valid session identifier which could allow an unauthenticated remote attacker to hijack a valid user session. The affected session identifiers are only used in a subset of the endpoints that are provided by the affected products. Siemens is preparing fix versions and recommends countermeasures for products where fixes are not, or not yet available.
The following versions of Siemens SIPROTEC 5 are affected:
- SIPROTEC 5 6MD84 (CP300) vers:intdot/<11.0 (CVE-2024-54017)
- SIPROTEC 5 6MD85 (CP200) vers:all/* ()
- SIPROTEC 5 6MD85 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 6MD86 (CP200) vers:all/* ()
- SIPROTEC 5 6MD86 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 6MD89 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 6MU85 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7KE85 (CP200) vers:all/* ()
- SIPROTEC 5 7KE85 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SA82 (CP100) vers:intdot/>=7.80 (CVE-2024-54017)
- SIPROTEC 5 7SA82 (CP150) vers:intdot/<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SA84 (CP200) vers:all/* ()
- SIPROTEC 5 7SA86 (CP200) vers:all/* ()
- SIPROTEC 5 7SA86 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SA87 (CP200) vers:all/* ()
- SIPROTEC 5 7SA87 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SD82 (CP100) vers:intdot/>=7.80 (CVE-2024-54017)
- SIPROTEC 5 7SD82 (CP150) vers:intdot/<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SD84 (CP200) vers:all/* ()
- SIPROTEC 5 7SD86 (CP200) vers:all/* ()
- SIPROTEC 5 7SD86 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SD87 (CP200) vers:all/* ()
- SIPROTEC 5 7SD87 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SJ81 (CP100) vers:intdot/>=7.80 (CVE-2024-54017)
- SIPROTEC 5 7SJ81 (CP150) vers:intdot/<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SJ82 (CP100) vers:intdot/>=7.80 (CVE-2024-54017)
- SIPROTEC 5 7SJ82 (CP150) vers:intdot/<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SJ85 (CP200) vers:all/* ()
- SIPROTEC 5 7SJ85 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SJ86 (CP200) vers:all/* ()
- SIPROTEC 5 7SJ86 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SK82 (CP100) vers:intdot/>=7.80 (CVE-2024-54017)
- SIPROTEC 5 7SK82 (CP150) vers:intdot/<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SK85 (CP200) vers:all/* ()
- SIPROTEC 5 7SK85 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SL82 (CP100) vers:intdot/>=7.80 (CVE-2024-54017)
- SIPROTEC 5 7SL82 (CP150) vers:intdot/<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SL86 (CP200) vers:all/* ()
- SIPROTEC 5 7SL86 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SL87 (CP200) vers:all/* ()
- SIPROTEC 5 7SL87 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SS85 (CP200) vers:all/* ()
- SIPROTEC 5 7SS85 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7ST85 (CP200) vers:all/* ()
- SIPROTEC 5 7ST85 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7ST86 (CP300) vers:intdot/<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SX82 (CP150) vers:intdot/<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SX85 (CP300) vers:intdot/<11.0 (CVE-2024-54017)
- SIPROTEC 5 7SY82 (CP150) vers:intdot/<11.0 (CVE-2024-54017)
- SIPROTEC 5 7UM85 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7UT82 (CP100) vers:intdot/>=7.80 (CVE-2024-54017)
- SIPROTEC 5 7UT82 (CP150) vers:intdot/<11.0 (CVE-2024-54017)
- SIPROTEC 5 7UT85 (CP200) vers:all/* ()
- SIPROTEC 5 7UT85 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7UT86 (CP200) vers:all/* ()
- SIPROTEC 5 7UT86 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7UT87 (CP200) vers:all/* ()
- SIPROTEC 5 7UT87 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7VE85 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7VK87 (CP200) vers:all/* ()
- SIPROTEC 5 7VK87 (CP300) vers:intdot/>=7.80|<11.0 (CVE-2024-54017)
- SIPROTEC 5 7VU85 (CP300) vers:intdot/<11.0 (CVE-2024-54017)
- SIPROTEC 5 Compact 7SX800 (CP050) vers:intdot/<11.0 (CVE-2024-54017)
| v3 5.3 | Siemens | Siemens SIPROTEC 5 | Small Space of Random Values |
CVE-2024-54017
Affected devices do not use sufficiently random values to create session identifiers. This could allow an unauthenticated remote attacker to brute force a session identifier and gain read access to limited information from the web server without authorization.
Siemens SIPROTEC 5
SIPROTEC 5 6MD84 (CP300), SIPROTEC 5 6MD85 (CP300), SIPROTEC 5 6MD86 (CP300), SIPROTEC 5 6MD89 (CP300), SIPROTEC 5 6MU85 (CP300), SIPROTEC 5 7KE85 (CP300), SIPROTEC 5 7SA82 (CP100), SIPROTEC 5 7SA82 (CP150), SIPROTEC 5 7SA86 (CP300), SIPROTEC 5 7SA87 (CP300), SIPROTEC 5 7SD82 (CP100), SIPROTEC 5 7SD82 (CP150), SIPROTEC 5 7SD86 (CP300), SIPROTEC 5 7SD87 (CP300), SIPROTEC 5 7SJ81 (CP100), SIPROTEC 5 7SJ81 (CP150), SIPROTEC 5 7SJ82 (CP100), SIPROTEC 5 7SJ82 (CP150), SIPROTEC 5 7SJ85 (CP300), SIPROTEC 5 7SJ86 (CP300), SIPROTEC 5 7SK82 (CP100), SIPROTEC 5 7SK82 (CP150), SIPROTEC 5 7SK85 (CP300), SIPROTEC 5 7SL82 (CP100), SIPROTEC 5 7SL82 (CP150), SIPROTEC 5 7SL86 (CP300), SIPROTEC 5 7SL87 (CP300), SIPROTEC 5 7SS85 (CP300), SIPROTEC 5 7ST85 (CP300), SIPROTEC 5 7ST86 (CP300), SIPROTEC 5 7SX82 (CP150), SIPROTEC 5 7SX85 (CP300), SIPROTEC 5 7SY82 (CP150), SIPROTEC 5 7UM85 (CP300), SIPROTEC 5 7UT82 (CP100), SIPROTEC 5 7UT82 (CP150), SIPROTEC 5 7UT85 (CP300), SIPROTEC 5 7UT86 (CP300), SIPROTEC 5 7UT87 (CP300), SIPROTEC 5 7VE85 (CP300), SIPROTEC 5 7VK87 (CP300), SIPROTEC 5 7VU85 (CP300), SIPROTEC 5 Compact 7SX800 (CP050)
known_affected, known_not_affected
None available
Currently no fix is available
Update to V11.0 or later version
https://support.industry.siemens.com/cs/ww/en/view/109814150/
https://support.industry.siemens.com/cs/ww/en/view/109757433/
https://support.industry.siemens.com/cs/ww/en/view/109796884/
Relevant CWE: CWE-334 Small Space of Random Values
| 3.1 | 5.3 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:N/A:N |
- SEC Consult Vulnerability Lab reported this vulnerability to Siemens.
Operators of critical power systems (e.g. TSOs or DSOs) worldwide are usually required by regulations to build resilience into the power grids by applying multi-level redundant secondary protection schemes. It is therefore recommended that the operators check whether appropriate resilient protection measures are in place. The risk of cyber incidents impacting the grid's reliability can thus be minimized by virtue of the grid design. Siemens strongly recommends applying the provided security updates using the corresponding tooling and documented procedures made available with the product. If supported by the product, an automated means to apply the security updates across multiple product instances may be used. Siemens strongly recommends prior validation of any security update before being applied, and supervision by trained staff of the update process in the target environment. As a general security measure Siemens strongly recommends to protect network access with appropriate mechanisms (e.g. firewalls, segmentation, VPN). It is advised to configure the environment according to our operational guidelines in order to run the devices in a protected IT environment. Recommended security guidelines can be found at: https://www.siemens.com/gridsecurity
This ICSA is a verbatim republication of Siemens ProductCERT SSA-786884 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
| 2026-05-12 | 1 | Publication Date |
| 2026-05-14 | 2 | Initial CISA Republication of Siemens ProductCERT SSA-786884 advisory |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-134-13
