Siemens Teamcenter is affected by multiple vulnerabilities which could potentially lead to a compromise in availability, integrity and confidentiality. Siemens has released new versions for the affected products and recommends to update to the latest versions.
The following versions of Siemens Teamcenter are affected:
- Teamcenter V2312 vers:intdot/<2312.0014, vers:intdot/<2312.0009 (CVE-2026-33862, CVE-2026-33893, CVE-2024-4367)
- Teamcenter V2406 vers:intdot/<2406.0012, vers:intdot/<2406.0006 (CVE-2026-33862, CVE-2026-33893, CVE-2024-4367)
- Teamcenter V2412 vers:intdot/<2412.0009 (CVE-2026-33862, CVE-2026-33893)
- Teamcenter V2506 vers:intdot/<2506.0005 (CVE-2026-33862, CVE-2026-33893)
- Teamcenter V2512 vers:all/*
| v3 7.5 | Siemens | Siemens Teamcenter | Improper Check for Unusual or Exceptional Conditions, Improper Neutralization of Input During Web Page Generation ('Cross-site Scripting'), Use of Hard-coded Credentials |
CVE-2024-4367
A type check was missing when handling fonts in PDF.js, which would allow arbitrary JavaScript execution in the PDF.js context. This vulnerability affects Firefox < 126, Firefox ESR < 115.11, and Thunderbird < 115.11.
Siemens Teamcenter
Teamcenter V2312, Teamcenter V2406
known_affected, known_not_affected
Update to V2312.0009 or later version
https://support.sw.siemens.com/product/282219420/
Update to V2406.0006 or later version
Relevant CWE: CWE-754 Improper Check for Unusual or Exceptional Conditions
| 3.1 | 5.6 | MEDIUM | CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:U/C:L/I:L/A:L |
CVE-2026-33862
The affected application does not properly encode or filter user-supplied data. This could allow an attacker to inject malicious code that can be executed by other users when they visit the affected page.
Siemens Teamcenter
Teamcenter V2312, Teamcenter V2406, Teamcenter V2412, Teamcenter V2506
Update to V2312.0014 or later version
Update to V2406.0012 or later version
Update to V2412.0009 or later version
Update to V2506.0005 or later version
| 3.1 | 7.3 | HIGH | CVSS:3.1/AV:N/AC:L/PR:L/UI:R/S:U/C:H/I:H/A:N |
CVE-2026-33893
The affected application contains hardcoded key which is used for obfuscation stored directly into the application. This could allow an attacker to obtain these keys and misuse them to gain unauthorized access.
Siemens Teamcenter
Relevant CWE: CWE-798 Use of Hard-coded Credentials
| 3.1 | 7.5 | HIGH | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N |
- Dustin Born, Robin Plugge, and Tim Wörner of usd AG reported these vulnerabilities.
This ICSA is a verbatim republication of Siemens ProductCERT SSA-827383 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
| 2026-05-12 | 1 | Publication Date |
| 2026-05-14 | 2 | Initial CISA Republication of Siemens ProductCERT SSA-827383 advisory |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-134-04
