Successful exploitation of this vulnerability could result in an unauthenticated attacker modifying critical device settings or factory resetting the device.
The following versions of Synectix LAN 232 TRIO are affected:
- LAN 232 TRIO vers:all/* (CVE-2026-1633)
| v3 10 | Synectix | Synectix LAN 232 TRIO | Missing Authentication for Critical Function |
- Critical Infrastructure Sectors: Critical Manufacturing, Emergency Services, Energy, Information Technology, Transportation Systems, Water and Wastewater
CVE-2026-1633
The Synectix LAN 232 TRIO 3-Port serial to ethernet adapter exposes its web management interface without requiring authentication, allowing unauthenticated users to modify critical device settings or factory reset the device.
Synectix
Synectix LAN 232 TRIO: vers:all/*
The affected products should be considered end-of-life, as Synectix is no longer in business and therefore firmware fixes, mitigations and updates will be unavailable.
| 3.1 | 10 | CRITICAL | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:C/C:H/I:H/A:H |
- Souvik Kandar of MicroSec (microsec.io) reported this vulnerability to CISA
- Initial Release Date: 2026-02-03
| 2026-02-03 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-034-04
