Ubia Ubox
  • CVSS v4 7.1
  • Vendor: Ubia
  • Equipment: Ubox
  • Vulnerability: Insufficiently Protected Credentials
Successful exploitation of this vulnerability could allow an attacker to remotely view camera feeds or modify settings.
The following product version is reported to be affected:
  • Ubox: v1.1.124
3.2.1 INSUFFICIENTLY PROTECTED CREDENTIALS CWE-522
The Ubia camera ecosystem fails to adequately secure API credentials, potentially enabling an attacker to connect to backend services. The attacker would then be able to gain unauthorized access to available cameras, enabling the viewing of live feeds or modification of settings.
CVE-2025-12636 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-12636. A base score of 7.1 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:L/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities
  • COMPANY HEADQUARTERS LOCATION: China
Milos C. reported this vulnerability to CISA.
Ubia did not respond to CISA's attempts to coordinate. Users of Ubia Cameras are encouraged to reach out out to Ubia for more information.
  • November 06, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-310-02
