Welker OdorEyes EcoSystem Pulse Bypass System with XL4 Controller
Successful exploitation of this vulnerability could result in an over- or under-odorization event.
The following versions of Welker OdorEyes EcoSystem Pulse Bypass System with XL4 Controller are affected:
  • OdorEyes EcoSystem Pulse Bypass System with XL4 Controller vers:all/* (CVE-2026-24790)
v3 8.2 Welker Welker OdorEyes EcoSystem Pulse Bypass System with XL4 Controller Missing Authentication for Critical Function
  • Critical Infrastructure Sectors: Chemical, Critical Manufacturing, Energy, Food and Agriculture
CVE-2026-24790
The underlying PLC of the device can be remotely influenced, without proper safeguards or authentication.
Welker
Welker OdorEyes EcoSystem Pulse Bypass System with XL4 Controller: vers:all/*
Welker did not respond to CISA's attempts at coordination. Users of Welker OdorEyes devices are encouraged to contact Welker and keep their systems up to date.
3.1 8.2 HIGH CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:H/A:L
  • A project sponsored by DHS S&T reported this vulnerability to CISA
  • Initial Release Date: 2026-02-19
2026-02-19 1 Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-050-04
