Successful exploitation of these vulnerabilities could allow an authenticated attacker to read or modify a remote database.
The following versions of Advantech WebAccess/SCADA are affected:
- WebAccess/SCADA (CVE-2025-14850, CVE-2025-14849, CVE-2025-14848, CVE-2025-46268, CVE-2025-67653)
| v3 8.8 | Advantech | Advantech WebAccess/SCADA | Improper Limitation of a Pathname to a Restricted Directory ('Path Traversal'), Unrestricted Upload of File with Dangerous Type, Absolute Path Traversal, Improper Neutralization of Special Elements used in an SQL Command ('SQL Injection') |
- Critical Infrastructure Sectors: Critical Manufacturing, Energy, Water and Wastewater
- Company Headquarters Location: Taiwan, Province of China
CVE-2025-14850
The affected product is vulnerable to directory traversal, which may allow an attacker to delete arbitrary files.
Advantech
Advantech WebAccess/SCADA: 9.2.1
Advantech recommends users apply the following mitigations update to WebAccess/SCADA: Version 9.2.2.
| 3.1 | 8.1 | HIGH | CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:H/A:H |
CVE-2025-14849
The affected product is vulnerable to unrestricted file upload, which may allow an attacker to remotely execute arbitrary code.
Advantech
Relevant CWE: CWE-434 Unrestricted Upload of File with Dangerous Type
| 3.1 | 8.8 | HIGH | CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H |
CVE-2025-14848
The affected product is vulnerable to absolute directory traversal, which may allow an attacker to determine the existence of arbitrary files.
Advantech
Relevant CWE: CWE-36 Absolute Path Traversal
| 3.1 | 4.3 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:L/I:N/A:N |
CVE-2025-46268
The affected product is vulnerable to SQL injection, which may allow an attacker to execute arbitrary SQL commands.
Advantech
Relevant CWE: CWE-89 Improper Neutralization of Special Elements used in an SQL Command ('SQL Injection')
| 3.1 | 6.3 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:L/I:L/A:L |
CVE-2025-67653
The affected product is vulnerable to directory traversal, which may allow an attacker to determine the existence of arbitrary files.
Advantech
- Alex Wiliams of Pellera Technologies reported these vulnerabilities to CISA
- Initial Release Date: 2025-12-18
| 2025-12-18 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-352-06
