Successful exploitation of this vulnerability could allow attackers with network access to alter operational settings, obtain sensitive signal data, or disrupt device availability.
The following versions of Anritsu Remote Spectrum Monitor are affected:
- Remote Spectrum Monitor MS27100A vers:all/* (CVE-2026-3356)
- Remote Spectrum Monitor MS27101A vers:all/* (CVE-2026-3356)
- Remote Spectrum Monitor MS27102A vers:all/* (CVE-2026-3356)
- Remote Spectrum Monitor MS27103A vers:all/* (CVE-2026-3356)
| v3 9.8 | Anritsu | Anritsu Remote Spectrum Monitor | Missing Authentication for Critical Function |
- Critical Infrastructure Sectors: Communications, Defense Industrial Base, Emergency Services, Transportation Systems
- Company Headquarters Location: Japan
CVE-2026-3356
The MS27102A Remote Spectrum Monitor is vulnerable to an authentication bypass that allows unauthorized users to access and manipulate its management interface. Because the device provides no mechanism to enable or configure authentication, the issue is inherent to its design rather than a deployment error.
Anritsu
Anritsu Remote Spectrum Monitor MS27100A: vers:all/*, Anritsu Remote Spectrum Monitor MS27101A: vers:all/*, Anritsu Remote Spectrum Monitor MS27102A: vers:all/*, Anritsu Remote Spectrum Monitor MS27103A: vers:all/*
Anritsu has no plans to fix this issue. Anritsu recommends that users deploy Remote Spectrum Monitor within secure network environments to mitigate potential risks.
Users can contact Anritsu Technical Support (1-800-267-4878) for more information.
- Souvik Kandar reported this vulnerability to CISA
- Initial Release Date: 2026-03-31
| 2026-03-31 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-090-01
