Successful exploitation of these vulnerabilities could allow attackers to conduct reconnaissance, capture or decrypt sensitive data, alter device configurations, gain unauthorized administrative or root‑level access, execute arbitrary code, compromise credentials or communications, and ultimately obtain full control over affected devices.
The following versions of Anviz Multiple Products are affected:
- CX2 Lite Firmware vers:all/* (CVE-2026-32648, CVE-2026-40461, CVE-2026-35682, CVE-2026-35546, CVE-2026-40066, CVE-2026-33569)
- CX7 Firmware vers:all/* (CVE-2026-33093, CVE-2026-35061, CVE-2026-32648, CVE-2026-40461, CVE-2026-35546, CVE-2026-40066, CVE-2026-32324, CVE-2026-31927, CVE-2026-33569)
- CrossChex Standard vers:all/* (CVE-2026-40434, CVE-2026-32650)
| v3 9.8 | Anviz | Anviz Multiple Products | Missing Authorization, Missing Authentication for Critical Function, Improper Neutralization of Special Elements used in a Command ('Command Injection'), Download of Code Without Integrity Check, Use of Hard-coded Cryptographic Key, Relative Path Traversal, Cleartext Transmission of Sensitive Information, Improper Verification of Source of a Communication Channel, Selection of Less-Secure Algorithm During Negotiation ('Algorithm Downgrade') |
- Critical Infrastructure Sectors: Commercial Facilities, Critical Manufacturing, Defense Industrial Base, Energy, Financial Services, Food and Agriculture, Government Services and Facilities, Healthcare and Public Health, Information Technology, Transportation Systems
CVE-2026-33093
CX7 is vulnerable to an unauthenticated POST to the device that captures a photo with the front facing camera, exposing visual information about the deployment environment.
Anviz
Anviz CX7 Firmware: vers:all/*
Anviz did not respond to CISA's attempts to coordinate these vulnerabilities. Users should contact Anviz for more information at https://www.anviz.com/contact-us.html.
Relevant CWE: CWE-862 Missing Authorization
| 3.1 | 5.3 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:N/A:N |
CVE-2026-35061
CX7 is vulnerable to the most recently captured test photo that can be retrieved without authentication, revealing sensitive operational imagery.
Anviz
CVE-2026-32648
CX2 Lite and CX7 are vulnerable to unauthenticated access that discloses debug configuration details (e.g., SSH/RTTY status), assisting attackers in reconnaissance against the device.
Anviz
Anviz CX2 Lite Firmware: vers:all/*, Anviz CX7 Firmware: vers:all/*
CVE-2026-40461
CX2 Lite and CX7 are vulnerable to unauthenticated POST requests that modify debug settings (e.g., enabling SSH), allowing unauthorized state changes that can facilitate later compromise.
Anviz
| 3.1 | 7.5 | HIGH | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:H/A:N |
CVE-2026-35682
CX2 Lite is vulnerable to an authenticated command injection via a filename parameter that enables arbitrary command execution (e.g., starting telnetd), resulting in root‑level access.
Anviz
Relevant CWE: CWE-77 Improper Neutralization of Special Elements used in a Command ('Command Injection')
| 3.1 | 8.8 | HIGH | CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H |
CVE-2026-35546
CX2 Lite and CX7 are vulnerable to unauthenticated firmware uploads. This causes crafted archives to be accepted, enabling attackers to plant and execute code and obtain a reverse shell.
Anviz
CVE-2026-40066
CX2 Lite and CX7 are vulnerable to unverified update packages that can be uploaded. The device unpacks and executes a script resulting in unauthenticated remote code execution.
Anviz
Relevant CWE: CWE-494 Download of Code Without Integrity Check
CVE-2026-32324
CX7 is vulnerable because the application embeds reusable certificate/key material, enabling decryption of MQTT traffic and potential interaction with device messaging channels at scale.
Anviz
Relevant CWE: CWE-321 Use of Hard-coded Cryptographic Key
| 3.1 | 7.7 | HIGH | CVSS:3.1/AV:L/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:N |
CVE-2026-31927
CX7 is vulnerable to an authenticated CSV upload which allows path traversal to overwrite arbitrary files (e.g., /etc/shadow), enabling unauthorized SSH access when combined with debug‑setting changes.
Anviz
Relevant CWE: CWE-23 Relative Path Traversal
| 3.1 | 4.9 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:H/UI:N/S:U/C:N/I:H/A:N |
CVE-2026-33569
CX2 Lite and CX7 administrative sessions occur over HTTP, enabling on‑path attackers to sniff credentials and session data, which can be used to compromise the device.
Anviz
| 3.1 | 6.5 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:R/S:U/C:H/I:N/A:N |
CVE-2026-40434
CrossChex Standard lacks source verification in the client/server channel, enabling TCP packet injection by an attacker on the same network to alter or disrupt application traffic.
Anviz
Anviz CrossChex Standard: vers:all/*
Relevant CWE: CWE-940 Improper Verification of Source of a Communication Channel
| 3.1 | 8.1 | HIGH | CVSS:3.1/AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:H/A:H |
CVE-2026-32650
CrossChex Standard is vulnerable when an attacker manipulates the TDS7 PreLogin to disable encryption, causing database credentials to be sent in plaintext and enabling unauthorized database access.
Anviz
Relevant CWE: CWE-757 Selection of Less-Secure Algorithm During Negotiation ('Algorithm Downgrade')
| 3.1 | 7.5 | HIGH | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N |
- An anonymous researcher reported these vulnerabilities to CISA
- Initial Release Date: 2026-04-16
| 2026-04-16 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-106-03
