Archive: Install Apache and Create Virtual Hosts in Ubuntu and CentOS
This is a re-post from a previous version of The Computer Crowd.
If you are reading this chances are you are looking on how to host multiple websites on a single server.
This guide is going to cover installing Apache2 and creating multiple virtual hosts, for different domains and / or subdomains. I will show examples in Ubuntu and CentOS. I started with a fresh install of both operating systems for this tutorial.
Note: I never suggest logging in as root. I would also run the service as a non-root user.
Ubuntu
Step 1: Install Apache2
sudo apt-get install apache2
Step 2: Create Directory Structure Personally I like the directory structure organized so I would do something like below.
sudo mkdir /var/www/domain1.com
sudo mkdir /var/www/domain2.com
Step 3: Create/Edit Your Virtual Hosts For this example you can just copy and paste the code below for each of your domains.
sudo nano /etc/apache2/sites-available/domain1.com
Be sure to change the information to your specific info.
<VirtualHost *:80>
        ServerAdmin [email protected]
        ServerName domain1.com
        ServerAlias www.domain1.com domain1.com
        DocumentRoot /var/www/domain1.com
        <Directory /var/www/domain1.com/>
                Options Indexes FollowSymLinks MultiViews
                AllowOverride all
                Order allow,deny
                allow from all
        </Directory>
        ErrorLog ${APACHE_LOG_DIR}/domain1.com-error.log
        CustomLog ${APACHE_LOG_DIR}/domain1.com-access.log combined
</VirtualHost>
Then repeat for additional domains.
Step 4: Enabling Your Virtual Hosts For each file you created above run the following command.
sudo a2ensite domain1.com
Once you have enabled all of your virtual hosts you then run.
sudo service apache2 reload
As long as your domains are pointed to your network and port 80 is open your domains should be directed to the correct virtual host.
CentOS
Step 1: Install httpd
sudo yum install httpd
Step 2: Have Apache Start at Boot
sudo chkconfig -levels 235 httpd on
sudo service httpd start
or with CentOS 7
sudo systemctl enable httpd
sudo systemctl start httpd
Step 3: Create Your Directory Structure
Repeat for any additional sites.
Step 4: Configure Your Virtual Hosts Open the httpd.conf
sudo vi /etc/httpd/conf/httpd.conf
Add the following lines to the bottom of httpd.conf be sure to hit “i” to insert text.
<VirtualHost *:80>
    ServerName www.domain1.com
    Document Root /www/domain1.com
    ErrorLog logs/domain1.com-error.log
    CustomLog logs/domain1.com-access.log combined
</VirtualHost>
Repeat for each additional host you want to add.
Save the file by hitting Esc and typing:
:wq
Step 5: Restart the Apache HTTPD
sudo service httpd restart
or in CentOS 7
sudo systemctl restart httpd
This is a companion discussion topic for the original entry at https://itbible.org/archive-install-apache-and-create-virtual-hosts-in-ubuntu-and-centos
