- CVSS v4 7.1
- Vendor: AVEVA
- Equipment: PI Data Archive
- Vulnerabilities: Uncaught Exception, Heap-based Buffer Overflow
Successful exploitation of these vulnerabilities could shut down necessary subsystems and cause a denial-of-service condition.
The following versions of PI Data Archive, as delivered by PI Server are affected:
- PI Data Archive: Versions 2018 SP3 Patch 4 and prior (CVE-2025-44019)
- PI Data Archive: Version 2023 (CVE-2025-44019, CVE-2025-36539)
- PI Data Archive: Version 2023 Patch 1 (CVE-2025-44019, CVE-2025-36539)
- PI Server: Versions 2018 SP3 Patch 6 and prior (CVE-2025-44019)
- PI Server: Version 2023 (CVE-2025-44019, CVE-2025-36539)
- PI Server: Version 2023 Patch 1 (CVE-2025-44019, CVE-2025-36539)
3.2.1 UNCAUGHT EXCEPTION CWE-248
The affected products are vulnerable to an uncaught exception that, if exploited, could allow an authenticated user to shut down certain necessary PI Data Archive subsystems, resulting in a denial of service. Depending on the timing of the crash, data present in snapshots/write cache may be lost.
CVE-2025-44019 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.1 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:L/A:H).
A CVSS v4 score has also been calculated for CVE-2025-44019. A base score of 7.1 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:N/VI:L/VA:H/SC:N/SI:N/SA:N).
3.2.2 UNCAUGHT EXCEPTION CWE-248
CVE-2025-36539 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-36539. A base score of 7.1 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
- COMPANY HEADQUARTERS LOCATION: United Kingdom
AVEVA Ethical Disclosure reported these vulnerabilities to CISA.
AVEVA recommends that organizations evaluate the impact of these vulnerabilities based on their operational environment, architecture, and product implementation. Users with affected product versions should apply security updates to mitigate the risk of exploit.
(CVE-2025-44019, CVE-2025-36539) All affected versions of PI Data Archive and PI Server can be fixed by upgrading to PI Server 2024 or higher. From OSISoft Customer Portal, search for "AVEVA PI Server" and select version 2024 or higher.
(CVE-2025-44019) PI Data Archive 2018 SP3 Patch 4 and all prior and PI Server 2018 SP3 Patch 6 and all prior can alternatively be fixed by upgrading to PI Server 2018 SP3 Patch 7 or higher. From OSISoft Customer Portal, search for "AVEVA PI Server" and select Version 2018 SP3 Patch 7 or higher.
AVEVA further recommends users follow general defensive measures:
- Monitor liveness of PI Network Manager and PI Archive Subsystem services.
- Set the PI Network Manager and PI Archive Subsystem services to automatically restart.
- Limit Port 5450 access to trusted workstations and software.
- For a list of PI System firewall port requirements, see knowledge base article KB01162 - Firewall Port Requirements.
- Impact and severity of vulnerabilities can be reduced through industry accepted IT practices. Please consult your IT engineer for advice on how to best implement these firewall restrictions in your organization's architecture. OSIsoft technical support provides guidance on architectural approaches, backup procedures, network defenses, and operating system configuration.
- For a starting point on PI System security best practices, see knowledge base article KB00833 - Seven best practices for securing your PI Server.
For additional information please refer to AVEVA-2025-001.
- June 12, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-162-07
