Successful exploitation of this vulnerability could result in an unauthorized access to the proxy server.
The following versions of AVEVA PI to CONNECT Agent are affected:
- PI to CONNECT Agent <=v2.4.2520 (CVE-2026-1495)
| v3 6.5 | AVEVA | AVEVA PI to CONNECT Agent | Insertion of Sensitive Information into Log File |
- Company Headquarters Location: United Kingdom
CVE-2026-1495
The vulnerability, if exploited, could allow an attacker with Event Log Reader (S-1-5-32-573) privileges to obtain proxy details, including URL and proxy credentials, from the PI to CONNECT event log files. This could enable unauthorized access to the proxy server.
AVEVA
AVEVA PI to CONNECT Agent: <=v2.4.2520
AVEVA recommends that organizations evaluate the impact of this vulnerability based on their operational environment, architecture, and product implementation.
Users of affected product versions should apply security updates to mitigate the risk of proxy details exposure in newly generated PI to CONNECT Agent event logs.
Users who have used affected product versions, should review existing PI to CONNECT Agent event logs (live/backups/copies) for exposed proxy connection details and consider purging the sensitive data from logs and/or configuring new credentials for access to the proxy service.
The following general defensive measures are recommended:
Remove use of plain text passwords in proxy URLs. Alternatively, if passwords are required by the proxy, then use least-privilege credentials.
Ensure only trusted users are given Event Log Reader (S-1-5-32-573) privileges on hosts where PI to CONNECT is installed.
Review existing PI to CONNECT event logs (live/backups/copies) for exposed proxy connection details and consider purging the sensitive data from logs and/or configuring new credentials for access to the proxy service.
All affected versions can be fixed by upgrading to PI to CONNECT Agent v2.5.2790 or higher. The latestversion of the agent can be downloaded from the CONNECT Data Services Portal here: https://datahub.connect.aveva.com/.
For additional information please refer to AVEVA-2026-003 https://www.aveva.com/content/dam/aveva/documents/support/cyber-security-updates/SecurityBulletin_AVEVA-2026-003.pdf.
Relevant CWE: CWE-532 Insertion of Sensitive Information into Log File
| 3.1 | 6.5 | MEDIUM | CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:C/C:H/I:N/A:N |
- AVEVA reported this vulnerability to CISA
| 2026-02-10 | 1 | Initial Republication of AVEVA-2026-003 |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-041-04
