AVEVA PI Web API
  • CVSS v4 4.5
  • Vendor: AVEVA
  • Equipment: PI Web API
  • Vulnerability: Cross-site Scripting
Successful exploitation of this vulnerability could allow an attacker to disable content security policy protections.
The following versions of AVEVA PI Web API are affected:
  • PI Web API: Versions 2023 SP1 and prior
3.2.1 IMPROPER NEUTRALIZATION OF INPUT DURING WEB PAGE GENERATION ('CROSS-SITE SCRIPTING') CWE-79
A cross-site scripting vulnerability exists in PI Web API version 2023 SP1 and prior that, if exploited, could allow an authenticated attacker (with privileges to create/update annotations or upload media files) to persist arbitrary JavaScript code that will be executed by users who were socially engineered to disable content security policy protections while rendering annotation attachments from within a web browser.
CVE-2025-2745 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (AV:N/AC:H/PR:L/UI:R/S:C/C:H/I:L/A:N).
A CVSS v4 score has also been calculated for CVE-2025-2745. A base score of 4.5 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:H/AT:N/PR:L/UI:A/VC:N/VI:N/VA:N/SC:H/SI:L/SA:N).
  • COMPANY HEADQUARTERS LOCATION: United Kingdom
AVEVA Ethical Disclosure reported this vulnerability to CISA.
AVEVA recommends that organizations evaluate the impact of these vulnerabilities based on their operational environment, architecture, and product implementation. Users of affected product versions should apply security updates to mitigate the risk of exploit.
From OSISoft Customer Portal, search for "PI Web API" and select version 2023 SP1 Patch 1 or higher.
AVEVA further recommends users follow general defensive measures:
  • Review and update the file extensions allowlist for annotation attachments to remove potentially vulnerable of undesired file types (ex: svg, pdf, ...).
  • Consider implementing IT policies that would prevent users from subverting/disabling content security policy browser protections.
  • Inform PI Web API users that annotation attachments should be retrieved through direct REST requests to PI Web API rather than rendering them in the browser interface.
  • Audit assigned privileges to ensure that only trusted users are given "Annotate" access rights.
For additional information please refer to AVEVA-2025-003.
  • June 12, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-162-08
