Successful exploitation of this vulnerability could allow an unauthenticated attacker to modify simulation parameters, training configuration and training records.
The following versions of AVEVA Pipeline Simulation are affected:
- Pipeline Simulation <=2025_SP1_build_7.1.9497.6351
| v3 9.1 | AVEVA | AVEVA Pipeline Simulation | Missing Authorization |
- Company Headquarters Location: United Kingdom
CVE-2026-5387
The vulnerability, if exploited, could allow an unauthenticated miscreant to perform operations intended only for Simulator Instructor or Simulator Developer (Administrator) roles, resulting in privilege escalation with potential for modification of simulation parameters, training configuration, and training records.
AVEVA
AVEVA Pipeline Simulation: <=2025_SP1_build_7.1.9497.6351
All affected versions can be fixed by upgrading to AVEVA Pipeline Simulation 2025 SP1 P01 (build 7.1.9580.8513) or higher. (https://softwaresupportsp.aveva.com/en-US/downloads/products/details/57b79fdb-7b5f-4125-8a44-833b6b5c6d6f)
For more information, please see AVEVA's security bulletin AVEVA-2026-004 (https://www.aveva.com/content/dam/aveva/documents/support/cyber-security-updates/SecurityBulletin_AVEVA-2026-004.pdf).
Restrict Network Access: Implement host-based and/or network firewall controls on all nodes hosting the Pipeline Simulation Server API to ensure that only trusted Pipeline Simulation client systems are permitted to establish connections.
Enforce Secure Communication: Enable TLS for all API communications and ensure that server certificates are properly managed and protected to reduce the risk of manipulator-in-the-middle(MitM) attacks and tampering with data in transit.
Relevant CWE: CWE-862 Missing Authorization
| 3.1 | 9.1 | CRITICAL | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:N |
- AVEVA reported this vulnerability to CISA
- Initial Release Date: 2026-04-16
| 2026-04-16 | 1 | Initial Republication of AVEVA-2026-004 |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-106-04
