Successful exploitation of this vulnerability could enable a remote attacker to alter critical system functions or disrupt device operation.
The following versions of Carlson Software VASCO-B GNSS Receiver are affected:
- VASCO-B GNSS Receiver <1.4.0 (CVE-2026-3893)
| v3 9.4 | Carlson Software | Carlson Software VASCO-B GNSS Receiver | Missing Authentication for Critical Function |
CVE-2026-3893
The Carlson VASCO-B GNSS Receiver lacks an authentication mechanism, allowing an attacker with network access to directly access and modify its configuration and operational functions without needing credentials.
Carlson Software
Carlson Software VASCO-B GNSS Receiver: <1.4.0
Carlson Software recommends users update to Version 1.4.0 or greater. For more information contact Carlson Software https://www.carlsonsw.com/support-and-training/
| 3.1 | 9.4 | CRITICAL | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:H/A:H |
- Souvik Kandar reported this vulnerability to CISA
- Initial Release Date: 2026-04-23
| 2026-04-23 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-113-02
