CloudCharge cloudcharge.se
Successful exploitation of these vulnerabilities could allow attackers to impersonate charging stations, hijack sessions, suppress or misroute legitimate traffic to cause large-scale denial of service, and manipulate data sent to the backend.
The following versions of CloudCharge cloudcharge.se are affected:
  • cloudcharge.se vers:all/* (CVE-2026-20781, CVE-2026-25114, CVE-2026-27652, CVE-2026-20733)
v3 9.4 CloudCharge CloudCharge cloudcharge.se Missing Authentication for Critical Function, Improper Restriction of Excessive Authentication Attempts, Insufficient Session Expiration, Insufficiently Protected Credentials
  • Critical Infrastructure Sectors: Energy, Transportation Systems
  • Company Headquarters Location: Sweden
CVE-2026-20781
CloudCharge
CloudCharge cloudcharge.se: vers:all/*
CloudCharge did not respond to CISA's request for coordination. Contact CloudCharge using their contact page here: https://cloudcharge.tech/support/contact/ for more information.
3.1 9.4 CRITICAL CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:L
CVE-2026-25114
CloudCharge
CVE-2026-27652
CloudCharge
CVE-2026-20733
CloudCharge
  • Khaled Sarieddine and Mohammad Ali Sayed reported these vulnerabilities to CISA
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-057-03
