Just a quick script on creating URL Shortcuts, defaults to the Public user desktop and has support for custom icons.
param (
[string]$Path,
[Parameter(Mandatory=$true)]
[string]$Name,
[string]$URL,
[string]$IconUrl,
[string]$IconPath = "C:\ITBible\Icons",
[boolean]$Force = $false
# Create a new com object
$wshShell = New-Object -ComObject "WScript.Shell"
# set default path to public desktop
if (-not ($Path))
$Path = $wshShell.SpecialFolders.Item("AllUsersDesktop")
# append \ to path if it does not exist
if ($Path -notmatch '\\$')
$Path += "\"
# append \ to icon path if it does not exist
if ($IconPath -notmatch '\\$')
$IconPath += "\"
$FullPath = Join-Path $Path "$($Name).url"
$FullIconPath = Join-Path $IconPath "$($Name).ico"
# If there is an icon make sure we can download it to the path and then download it
if ($IconUrl)
if (-not (Test-Path -Path $IconPath))
New-Item -ItemType Directory -Force -Path $IconPath
Invoke-WebRequest -Uri $IconUrl -OutFile $FullIconPath
# verify the path exists or create it
if (-not (Test-Path -Path $Path))
New-Item -ItemType Directory -Force -Path $Path
# Create the shortcut
$urlShortcut = $wshShell.CreateShortcut($FullPath)
$urlShortcut.TargetPath = $URL
$urlShortcut.Save()
if ($IconUrl)
Add-Content -Path $FullPath -Value "IconFile=$($FullIconPath)"
Add-Content -Path $FullPath -Value "IconIndex=0"
[System.Runtime.InteropServices.Marshal]::ReleaseComObject($urlShortcut) | Out-Null
[System.Runtime.InteropServices.Marshal]::ReleaseComObject($wshShell) | Out-Null
[System.GC]::Collect()
[System.GC]::WaitForPendingFinalizers()
