The following versions of CTEK Chargeportal are affected:
- Chargeportal vers:all/*
| v3 9.4 | CTEK | CTEK Chargeportal | Missing Authentication for Critical Function, Improper Restriction of Excessive Authentication Attempts, Insufficient Session Expiration, Insufficiently Protected Credentials |
- Critical Infrastructure Sectors: Energy, Transportation Systems
- Company Headquarters Location: Sweden
CVE-2026-25192
CTEK Chargeportal
CTEK
CTEK Chargeportal: vers:all/*
CTEK will be sunsetting this product in April 2026. Please contact CTEK for more information https://www.ctek.com/support.
| 3.1 | 9.4 | CRITICAL | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:L |
CVE-2026-31904
CTEK Chargeportal
CTEK
CVE-2026-27649
CTEK Chargeportal
CTEK
| 3.1 | 7.3 | HIGH | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:L/A:L |
CVE-2026-28204
CTEK Chargeportal
CTEK
| 3.1 | 6.5 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:L/A:N |
- Khaled Sarieddine, Mohammad Ali Sayed reported these vulnerabilities to CISA
- Initial Release Date: 2026-03-19
| 2026-03-19 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-078-06
